oil leak from header bolt?
Old 04-01-2013, 11:25 AM
billkmiami's Avatar
Question oil leak from header bolt?
Just replace my valve cover gasket- cleaned up most of the oil buildup as possible- after running the motor with the new gasket- all leaks around the valve cover are gone! But i still seem to have oil seeping from my first cylinder header bolt/nut. It is the bolt/nut closest to the front of the motor. I was able to tighten the nut a bit but it still has oil seeping out. I suspect this has been happening for years since the oil buildup was very thick- what do you think is causing this leak?
Old 04-01-2013, 11:26 AM
billkmiami's Avatar
Soory- I have a 2001 Tacoma with the 2.7l motor- 190,000 miles- still runs perfect!
Eggslinger
06-08-2019 03:32 PM
09-04-2015 09:27 AM
jakebarrett
07-10-2015 07:15 PM
Coreyr384
07-10-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: oil leak from header bolt?
