OH MAN!!....Don't tell me there's a problem with the rack!!
#61
Originally Posted by BruceTS
Yes the inner tie rod can be replaced.....
After refreshing myself with this thread and reading the original post, I doubt that rack was toast if only one side had play, most likely a worn joint.
Which joint do you mean?
#62
I think he means an inner tie rod.
Only one side on mine has play but after replacing both inners with new oem ones there is still play, so my rack is the culprit. I believe it's just the rack guide though.
