OBD2 2000 and newer smog question
Old 12-03-2015, 02:20 PM
anniesball's Avatar
Any members in CA know if you swap the ECM with the same model year if the smog test will fail due to VIN mismatch?
I'm asking because I'm going to swap out my 2002 4Runner auto ECM for a 2002 tacoma manual ECM for a transmission swap.
I want to know prior to the sway so I don't end up not passing smog.
I have a call into BAR awaiting a call back from a referee...
Old 12-03-2015, 03:22 PM
anniesball's Avatar
Or to say it differently, has anyone ever failed SMOG test due to a VIN mismatch?
Old 12-04-2015, 09:16 AM
SacRunner's Avatar
Not from a VIN mismatch, but you'll fail the visual because of the transmission swap.
As far as I know, you will need to go in for a SMOG Ref inspection after performing the transmission swap, then from that point forward, your 4Runner will be SMOGed as a 2002 Tacoma and you'll get a new firewall sticker.
It sounds like you're on the right track with a call into the ref, definitely do what they say.
Old 12-04-2015, 09:31 AM
anniesball's Avatar
Thanks for the info! I didn't know when the vehicle was SMOG'd that they also visually looked at transmission. I do have a call into the ref to get this sorted. Hopefully I hear back soon as I don't have much life left in my auto....
spiewaker
12-16-2015 01:10 PM
Naween Zohab
11-10-2015 03:56 PM
TURBOrunnerNM
10-05-2015 03:10 PM
Flightguy
10-02-2015 05:34 PM
LCE_Performance
10-01-2015 01:03 PM
Quick Reply: OBD2 2000 and newer smog question
