Now What?...Spare Tire Removal Q
Old 04-22-2004, 07:04 PM
cool rob's Avatar
After running on 33" tires for about four months now, I decided that I needed to finally remove the stock spare and replace it with a 33"(the spare was a 31"). One problem: since I have a 2-inch body lift, the jack handle cannot reach the nut to turn the tire winch due to the angle of the bumper hole and the winch nut created by the lift. Someone please tell me there is a simple solution to this problem...
Old 04-22-2004, 07:07 PM
SolidDigital's Avatar
I don't know how much different yours would be from mine, but when I first got mine loose I just used enough of the handle to go past the tire and loosened it without even having it past the rear bumper/body panel.
Old 04-22-2004, 07:09 PM
Guest
Yoter's Avatar
Simply remove your entire bumper every time you need to access the spare. lol ok or not. Have the access tool fabbed or drill a new access hole.
Old 04-22-2004, 07:11 PM
Guest
Yoter's Avatar
Another smarter option is to get a roof basket and show the 33 off.
Old 04-22-2004, 07:18 PM
cool rob's Avatar
Thanks for the ideas, fellas. I'm leaning towards drilling a new access hole AND getting a roof basket. If I screw up my bumper, I'll have a good excuse to buy new custom one!
Old 04-22-2004, 07:25 PM
My99's Avatar
Ya, putting your heavy tire on your roof is great for many reasons. Increases wind drag and noise. Decreases fuel mileage. Makes your CG even higher than it was before, and you'll even snag a few more branches than before. But hey, you'll impress all the 8-14 yr olds.
Ya, i'm just jokin. It does have some benefits too, but..
If you can fit a 33 under your truck, i'd suggest doing that. As far as your problem... I've never been there so can't say.
Old 04-22-2004, 07:31 PM
Guest
Yoter's Avatar
HaHaHaHaHa forgot to laugh. I am going to be the BIGGER man and not flame the crap out of you 99. Fab your bumper with a new access hole. The roof rack comment was incase you were not fond of hacking your rig.
Old 04-22-2004, 07:37 PM
cool rob's Avatar
I think mounting a 33" spare may be out of the question since I do have a trailer hitch. From looking at it earlier, it's going to be a super tight fit- if it even fits at all.
Old 04-22-2004, 08:49 PM
doink's Avatar
another vote against having it up top. i say if you have enough cargo room in the back, maybe try to pop it in there for the time being...but then again, its your call.
Old 04-25-2004, 09:21 PM
outlaw27's Avatar
I have the same problem as you. I was going to post a thread about it. I was trying to take my spare out, and couldnt figure out why I couldnt lower it. Then I realized it was mounted to frame and the body was higher after the 2" body lift. Hopefully you can get it out. If you do let me know I've been trying to figure it out. Oh and one of my buddies fit a pretty worn down 285/75/16 under his truck. It fit perfect. Just to let you know
Old 04-25-2004, 09:53 PM
Robinhood150's Avatar
I thought you got that high CG thing out of your system?
Old 04-25-2004, 10:07 PM
PoBoy's Avatar
Just use a 3/4 socket extension and a monkey wrench...crawl underneath and find the winch hole...insert and turn. Its really easy. You are going to get dirty anyways changing a spare...so who cares if you ahve to crawl under there and find the hole.
Old 04-26-2004, 04:57 AM
waskillywabbit's Avatar
Talking No No No
SIMPLE FIX:
Pop off the top plastic piece that is on top of the bumper, takes all of 5 seconds to take off or put on, and there is the spot you need to access.
Old 04-26-2004, 06:51 PM
cool rob's Avatar
Originally Posted by waskillywabbit
SIMPLE FIX:
waskilly...hmmmm, I'll try that tomorrow. I tried again to figure out a way to lower the spare(before I checked this thread today) and I found myself attempting to remove the bumper and snapping a bolt that holds the bumper and end cap together in the process That was my cue to quit. If the removing that plastic piece thing doesn't work(it just pops off, right?), I'll try PoBoy's idea. Thanks for the ideas, fellas.
Old 04-27-2004, 04:14 AM
Talking Yep
Pops right off. The plastic bumper piece has about 8 clips on it that clasp through holes in the bumper and one on each end that clasp on the top of the wing next to the door.
Check a Hayne's or Chilton's if you wanna see where to pull, but just grab it where you can get a finger under it and just pop it up with firm pressure.
Good luck!
Old 04-28-2004, 02:08 PM
cool rob's Avatar
SIMPLE FIX:
waskilly...you da man. Taking the plastic piece off and accessing the winch worked like a champ! One day I hope to be as smart as you. My 33" spare fits perfectly underneath,too,trailer hitch and all.
Old 04-28-2004, 02:15 PM
Tman100z's Avatar
Hey ROB
I finally got my truck lifted but i would still love to check yours out. Ill email you and maybe we can get together this weekend.
Terence
Old 04-28-2004, 03:15 PM
Talking Cool Rob
Glad to help! Perhaps one day I can be as "cool" as you!
Old 04-28-2004, 05:57 PM
cool rob's Avatar
Originally Posted by Tman100z
Hey ROB
Terence
Terence...what kind of lift/tires/wheels did you end up getting? I want to check your rig out too, but I'm heading up north for the weekend. We'll hook it up some other time.
Old 04-28-2004, 06:12 PM
SteveO's Avatar
I don't know Blue....my aluminum wheel and tire weighs in at 80lbs. It wasn't too fun getting it up ther and back off. Had to use a step ladder...
Flying91
45
04-11-2024 04:39 PM
BushPig
10-29-2022 06:26 AM
djpg2000
11-11-2020 04:56 AM
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
Quick Reply: Now What?...Spare Tire Removal Q
