New Yota, few questions
Old 02-06-2009, 03:04 PM
Real----Estate's Avatar
99 runnner SR5 with 205k
Good dealer records and one owner car.
Tomorrow getting alignment and oil changed (they are doing that as an IOU, yes I can change my own)
Considering the following and since I am "new" to toyota's wanted to get some feedback on some things.
-Spark Plugs, nothing really making me think I need them other than no record of them being changed, so cheap it is worth it in my opinion. What kind is recommended for the 3.4l as a daily driver? I want the best performing ones so let me know what you recommend!
-Power Steering Flush - What is the "mechanical level" of doing this on your own in this truck? Or just like any other.
-Manual Tranny - just buy Toyota fluid, drain, pump in and plug back up?
-MAF Cleaning - Recommended? Once again 205k and no records of replacement on this.
-Keeping Yota Air Filter- Been advised by others........you?
-Brakes front and rear- no question here but installing new pads/rotors.
Anything else to keep this puppy running strong? Im easy on the pedal.
Also ANY WAY TO KEEP THIS THING FROM AUTO LOCKING ONCE I GET OUT???? It seems it locks itself once im out. I come from being able to control my whole car from my laptop and controlling this.......but i dont have hooks or software for this rig. Dealer can help?
THank you all and I look forward to a long life getting help and helping others here in YotaTech! Sofar this has been a great forum for me!
Old 02-07-2009, 06:41 PM
raydouble's Avatar
Toyota OEM
2 people, don't let the pump run dry.....Front tires off the ground, return hose in a five gallon bucket.... until fluid coming out pump return hose is clean.
Get hot, drain, fill with factory recommended fluid (check your owners manual) my buddy likes Redline MT90
Clean with high quality electronics cleaner
OEM Toyota always for me
OEM for brakes for me
Can't speak to the locking issue.
Old 02-07-2009, 07:28 PM
skjos's Avatar
-Spark Plugs
NGK BKR5EKB-11
Also do the wires NGK NGK TE66
I use a turkey baster
-Manual Tranny
I have an auto, but with 205K I would stick with OEM fluid
-MAF Cleaning
Yes, take a look at the throttle body why you're in there.
Yes, slap in a new OEM filter
Rotors - switch them to Brembo, OEM pads are fine
-Also ANY WAY TO KEEP THIS THING FROM AUTO LOCKING ONCE I GET OUT???? This might help: http://www.customtacos.com/tech/file...rogramming.pdf
shisha1999
08-14-2015 01:33 AM
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
nonstop
07-24-2015 06:29 PM
Quick Reply: New Yota, few questions
