New Lower Control Arm Skids Installed
I received the rear lower control arm skids from Toytec Lifts that I won through UltimateYota.com a couple of weeks ago. I finally had time today to install and paint them. Take a look at the pictures here.
My first impression is that these things are super beefy. I am not going to be worried about my control arms bending when I slide them over rocks anymore. The skids were a perfect fit! I cleaned them up, painted the sections that I wouldn't be able to access once the skids would be installed, sanded the weld locations on the LCA's down to bare metal, welded the skids on, then finished the paint job. Super easy, two hour job.
Enjoy.
Enjoy.
I bought a set. They are great! Hands down the best I've seen for the money. Machined to fit the stock trailing arms perfectly. I was going to tack them up while still on the vehicle but they fit so well there was no need. I just cleaned up the stock arms and welded 'em on. Just to make sure I don't get water trapped in there I ran a bead of silicone all around to seal it off. I welded up some channel steel for a friends Landcruiser but we were only able to find 1/8" thick channel. At the base the Toytec skids are nearly a 1/2" thick!
Here's some pics:
The rest of the photos can be seen here:
Pics of Rear Lower Control Arms
Here's some pics:
BeMiceElf
10-10-2015 09:40 PM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
rushw
07-18-2015 01:46 PM
