YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 01-28-2005, 07:27 AM   #1 (permalink)
GodwinAustin's Avatar
New Donahoe Spacer Lift
Does anyone know much about this new spacer lift from Donahoe?
Donahoe Racing Enterprises announces the release of their new Tacoma pre-runner, 4WD & 4-Runner Spacer Leveling Kit.
Anaheim, CA. (September 14, 2004) The new Donahoe Racing Tacoma Spacer Leveling Kit is a very cost effective way of leveling out a Tacoma / 4-Runner truck without dropping the shock to incorrect or dangerous heights.The kit integrates correct shock position for maximum wheel travel and spring load, and will not over-extend ball joints. Both lift and additional droop travel are built into one unit, which completely replaces the stock upper shock mount. The spacers are made from billetaluminum for corrosion resistance and are black-anodized for a sleek appearance. Upper mount studs are pre-installed for easy installation.
__________________
-Jon
85 4Runner - 5Spd - 3 inch Downey spring lift - 2" body lift
GodwinAustin is offline
Sponsored Links
To remove this ad, register today!
Old 01-28-2005, 08:34 AM   #2 (permalink)
Good Times's Avatar
Send a message via AIM to Good Times
Not much but it looks like it replaces the entire top plate like the Cornfed's. A much better design I think btw.
Donahoe makes some fabulous products that are $$ and it looks like this is their ticket into the entry level.
Good Times is offline
Old 01-28-2005, 10:09 AM   #3 (permalink)
Guys - heres the answer from Donahoe:
It is not a top load spacer, it replaces the factory upper mount
completely.
The DR spacer moves the stem of the shock down 3/8” (top load) and
preloads the spring an additional 1.5”
These are measurements at the shock, this equates to an additional ¾”
more wheel travel and 2.5” more ride height due to the leverage ratio of
the A-arm.
This is the most “top load” the upper ball joint can handle. It is
intended to be used with the factory black shocks or the TRD Bilsteins.
The blue Tokiko shocks are not intended for this lift as they do not
have the same travel and the shock would be topped out. Other
aftermarket shocks that are longer would be problematic, use at your own
risk and take some careful measurements vs. stock
Dylan Evans
R&D Engineer
__________________
-Jon
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Spacer Lift Bryan06runner 03+ 4Runner/GX470, & 05+ Tacomas 2 04-04-2007 11:00 AM
Spacer lift Hoopster 95.5-2004 Tacomas & 96-2002 4Runners 16 02-13-2007 02:21 PM
spacer lift: topout extender vs preload spacer Rishi Offroad Tech 15 04-17-2005 05:18 PM
Donahoe Coilover Lift the Best - 1999 4runner Ltd --------------------------- montypower Offroad Tech 7 03-31-2005 10:23 PM
4th Gen. Donahoe Suspension Lift Coming bubbamango 03+ 4Runner/GX470, & 05+ Tacomas 31 02-14-2005 10:49 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
