YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 10-02-2004, 05:57 PM   #1 (permalink)
SlimJim248@earthlink's Avatar
new clutch noise
I have an 89 pickup 2wd and I just replaced the clutch cover, disk, throw out and pilot bearing. Ever since I did that when I drive it clicks. It speeds up with the engine, but when my truck warms up after a while, the sound seems to go away, but comes back after it sits. It sounds like a loud valve noise, but it has to be something with the clutch since it started when I replaced it. It only happens when I am on the gas though. I am hoping maybe it will go away. Anyone had this happen, Thanks in advance.
__________________
1985 4runner
32x11.5 BFG mud-terrains, Dual case with 4.7 gears, Rear detroit locker, home made front and rear bumpers, 22re
SlimJim248@earthlink is offline
Sponsored Links
To remove this ad, register today!
Old 10-03-2004, 07:30 PM   #2 (permalink)
Unhappy99's Avatar
If I recall correctly, the exhaust pipe bolts to the left side of the bell housing, and just above this is a pipe joint to the exhaust manifold.
Its leaking at or near this joint.
__________________
03 Dodge Ram 2500 CTD...its amazing
Ex: 1999 4Runner JT3HN86R1X0199261...Now somebody elses Karl Malone Toyota 'Certified' POS
Legendary Toyota quality is exactly that: A thing of legend.
Defective fuel gauge - 'Certified'
Defective brake rotors - 'Certified'
Defective axle seals - 'Certified'
Defective heater diverter - 'Certified'
etc. etc. etc.
Unhappy99 is offline
Old 10-04-2004, 11:16 AM   #3 (permalink)
Yeah, thanks for the reply, that is what it was and I found it right after I posted. The bolts were tight, but I guess they needed just a little more. Thanks
__________________
1985 4runner
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
squealing noise when clutch is out Riverboy 86-95 Trucks & 4Runners 4 10-05-2006 06:40 PM
Help with clutch noise. TYOTA 95.5-2004 Tacomas & 96-2002 4Runners 11 09-08-2006 11:18 AM
Tundra Clutch Noise Lee Landis 95.5-2004 Tacomas & 96-2002 4Runners 2 10-21-2004 08:16 AM
Clutch Noise??? DreamToy 95.5-2004 Tacomas & 96-2002 4Runners 4 02-03-2004 06:56 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
