need source for 1 small part for a cup holder mod.
Good day all..
I am trying to find a place to get a small part so I can install a 99 centre console into my 97.
I have searched the forum but some of the links are old & are now gone. By using the search i have found the parts & how-to etc, but im missing one item.
I have the 99 console, newer break lever, I am just in need of part #89180-35010.
From what I understand this will make replacing the pretty much plug & play(ish). I recall people mentioning Toyota was very expensive for this small part which enables the brake handle to be re-positioned. I have scoured local wreckers (where I found the console, which was already removed) but no luck.
Any forthcoming info would be very appreciated.
Attached images are from a fellow 4runner user.
Allan
Allan
Good day all..
I am trying to find a place to get a small part so I can install a 99 center console into my 97.
I have searched the forum but some of the links are old & are now gone. By using the search i have found the parts & how-to etc, but I'm missing one item.
I have the 99 console, newer brake lever, I am just in need of part #89180-35010.
I'll see if I can find a better part number on a '99.
[EDIT] I don't see that piece on the parking brake on a '99. Where does it fit?
that gold-colored piece fits under the center console in 2001 and 2002 models with the yaw rate sensor; it is actually the mounting bracket which holds the sensor itself, but it bolts to the tub of the truck, and then the center console bolts to the gold-colored mounting bracket through the two holes within the center console when you open its main lid...
Avenged
07-09-2015 07:55 AM
