need help
need help
I Got A 1993 4 Cyl. P/u 22-re , Stck Shift, 290000 Miles. The Idel Keeps Reving Up And Down Also The Exhaust Smells Foul, This Is Been Going On For A Week Now , It Did Stop For A Day And The Idel Was Normal But Its Doing It Again,
I Do Not Have Shop Manual, Can Someone Help Thanx
Does it happen only when you step on the break with the A/C on? That happened to mine for seemingly no reason. I just adjusted the idle down and it runs fine now. The exhaust though, I don't know. Cat clogged up? Bad oxygen sensor? Bad oxygen sensor clogged the cat up?
I am working on putting the service manual for the '93 online with all my .pdf files. You can find it here http://personal.utulsa.edu/~nathan-b...fsm/index.html . The engine section is complete, you can look in that. The troubleshooting charts seem pretty handy, though they are kinda tricky at first. Good luck
