manual hubs
manual hubs
are there ways to lock your manual hubs so that when your car is parked somewhere someone can't come along and engage your front axle without you knowing....or do you just have to check everytime before you drive.....and what would happen if someone did and you didn't realize.............thanks
no way to lock but
if someone locks it, no problem it will just use a little more gas because of the extra drag.
the trucks are built better than some tanks!
David
David
Rabidbeaverbaby,
David in germany said it all. But then again it won't hurt you to check them hubs to make sure those arrows are pointing at FREE mark before you hop in your rig. It won't take but a minute to eyeball them pointers. Just like doing a pre-flight inspection before you take-off.
Noel
Noel
FS[SouthEast]: Aisin factory hubs, cleaned and lubed
carlspeed
08-23-2015 02:59 PM
Steven.m.paulk
07-24-2015 01:44 PM
