MAF differences?
MAF differences?
i have a 96 3.4L 4runner and i wanted to clean it the other day, went to the tread on 4x4wire and got the directions. well i could not find out how to get the actual MAF exposed, like on the pictures and i was wondering if on the 96's if they can be exposed or not because i could not fiqure out how to do it. and was wondering if other 3rd gen MAF are differnt from the 96 like mine.
I had the same problem myself, but apparently they changed the MAF design on the later 4Runners. In my search I found that you are supposed to just spray contact cleaner inside the MAF itself instead of the wires, because we do not have the screws that goes into the MAF sensor.
This thread should help with the cleaning on your type:
http://www.4x4wire.com/forums/showfl...rue#Post106649
If you want to switch to the newer style that has been done too:
https://www.yotatech.com/forums/f2/96-4-runner-maf-harness-pin-out-57454/
djohnson13
09-04-2015 12:35 PM
Seatbelts
7
08-29-2015 11:48 AM
