Locker for Daily Driver - Page 3 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-02-2006, 04:24 PM   #51 (permalink)
Mr. Bob's Avatar
This is right off the aussie locker web page:
"If only installing one locker should I install in the front or rear?"
"We "Do Not" recommend the installation of a locker in the front of a vehicle that will be driven on icy highways in 4WD without manual hubs.
* If a vehicle has an IFS (Independent Front Suspension) system then the front installation will result in a dramatic increase in 4WD capability. This is because all IFS vehicles have very limited suspension movement (wheel travel and articulation) resulting in easily lifted wheels and a loss of front traction. Installing a front locker will solve the deficiency.
* If a vehicle has LSD (Limited Slip Differential) in the rear, then a front installation provides a significant improvement over the existing LSD and open diff set-up.
* If a vehicle has constant 4WD then only a rear installation should be considered.
* A front installation will usually yield the greatest improvement in off-road capability. This is due to the general requirement of increased in traction under hill climbing or rock crawling. Under full climbing conditions, due to the angle of the vehicle, the rear wheels carry a much greater weight (weight transfer) and therefore, the front carries less weight and tends to break traction very easily.
Once one front wheel starts to spin the other wheel stops turning and the whole front diff ceases to provide traction. At this point the load is transferred to the rear diff as if the vehicle was a 2WD and due to the increased load the rear wheels tend to spin and the vehicle stops. If you can stop the front wheel from spinning you have solved the traction problem. In addition to the traction performance a front installation does not introduce any changes in handling characteristics. "
__________________
97 Stellar Blue Pearl 4Runner, 3.4L 5 Speed, Elocker, OEM Lift, 285/75/R16 Cooper Discoverer STTs on FZJ-80 rims, TRD clutch, TRD Headers, Borla cat back exhaust, Deck plate and ISR mods.
mods waiting for truck:
FJ40 logo for satoshi mod
"Amber" corner lenses
Hilux Surf emblem
Mr. Bob is offline
Old 02-02-2006, 04:29 PM   #52 (permalink)
Send a message via AIM to JHupp
wow, so I will only notice a front locker when in 4wd, it really makes much more sense to me because in my truck with a center diff lock, there is a 50/50 split betweenthe front and rear, and the front wheels loose traction much easier. I just want to be sure, that the lcoker will only work when in 4wd, and not in 2 wheel. I want this vehicle to handle like stock in 2 wheel, but be as nasty as it wants in 4wd. Thanks, somebody just please confirm. Thanks,
Jason
__________________
Jason
'06 F250 Super Duty Daily Driver
'01 Toyota 4Runner Sport 265/75/16 BFG ATs, OME 881s w/ spacers front, OME 891s rear, SS roll bar, and some other stuff. Out of Commision
njttora.com
JHupp is offline
Old 02-02-2006, 04:37 PM   #53 (permalink)
also, on all of the charts I see, the fitment chart for the front only goes up to 1999. I have allready purchased a 1620 model, but I dont think the front and rear diffs are the same, so I probably wont be able to install it in the front. I'm guessing I will have to return it to purchase a different model for the front. Anybody know what model lock-right is made for the front diff of an '01 Runner? Thanks in advance!!!
__________________
Jason
njttora.com
JHupp is offline
Old 02-02-2006, 04:46 PM   #54 (permalink)
Mr. Bob's Avatar
The ultimate setup would be the toy Elocker swap into the rear, and an aussie in the front....
That is the setup my buddy went with in his 1st gen runner and drives completly stock on road, and walks almost everything off road....
An aussie in the front will not lock untill powered... so as long as the drive shaft is not spinning, then it acts as an open diff.... that is why you cann't install an aussie into an AWD vehicle.... I have one in the front of my bronco.... and love it!! big time improvment!!!
__________________
Hilux Surf emblem
Mr. Bob is offline
Old 02-02-2006, 04:48 PM   #55 (permalink)
Mr. Bob's Avatar
and aussie goes 1986-2000
__________________
Hilux Surf emblem
Mr. Bob is offline
Old 02-02-2006, 04:51 PM   #56 (permalink)
Nice, it basically has to be a lockright, because that is what I bought, the part # for the lockright is 1611, do you know if it will also be unnoticeable in 2wd? I believe they all work the same, but just wanted to double check. Thanks!
__________________
Jason
njttora.com
JHupp is offline
Old 02-02-2006, 04:57 PM   #57 (permalink)
amorphous's Avatar
Send a message via MSN to amorphous Send a message via Yahoo to amorphous
dued, do you have ADD or manual hubs?
__________________
98 4runner sr5
33"s and locked with the usual suspects
amorphous is offline
Old 02-02-2006, 04:58 PM   #58 (permalink)
Mr. Bob's Avatar
It will work fine so long as it is not AWD.... Now that I think of it, my buddy is running the Lockright 1611 in his '88....
__________________
Hilux Surf emblem
Mr. Bob is offline
Old 02-02-2006, 04:58 PM   #59 (permalink)
tc
tc's Avatar
Doesn't the ADD disconnect one of the axles out of the carrier?
Even if it doesn't, manual hubs would make the locker transparent on the road. If you live where it snows, manual hubs would allow you to avoid the apparently sketchy handling of a locked front in the snow by only locking one hub and having 3WD.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 02-02-2006, 05:45 PM   #60 (permalink)
I am not sure what I have up front, it is definately not Manual Hubs. I NEVER run in 4wd, unless it is very very snowy on the side streets in my neighborhood. In this sitation a front locker would probably be better. The only other time I use 4wd would be offroad, where I think the locker would make a huge difference, hopefully in a good way. The lockright says that it ratchets, so the wide turns shouldnt be bad at all. And for tghter technical sections, if I really had to, I could take it out of 4 wheel really quick. On road, if I ever had to use the 4wd, it would be in the snow, but like I said, I have NEVER had to use 4wd at above 20mph on the streets here,and even if I did, the ATRAC in my Runner should be able to help with any kind of slide or skid. I think this locker would be the bet choice, and I am trying to get the guy to change my order. Like I said, I just want the front locker to be completely unnoticeable in 2wd, it can be as nasty as t wants in 4wd.
__________________
Jason
njttora.com
JHupp is offline
Old 02-02-2006, 05:49 PM   #61 (permalink)
Silver_Truck's Avatar
I wouldn't lock the front of my DD with a full time locker unless you have manual hubs. Just put the locker in the rear, you already bought it and it really isn't that noticeable, you'll get used to it in a couple days and you'll automatically adjust your driving style to make it work, you won't even notice the adjustment it'll become natural very quickly.
__________________
-Geoff
*1991 Toyota Pickup Ext. Cab SR5 4x4 V6 5 spd K&N intake, port & polished heads with OS valves, port & polished intake manifold and plenum, NWOR headers and crossover, NWOR catback, Denso Iridium plugs, Redline Fluids, 4.88s, Rear LockRight, Aisin hubs, Chevy springs, BJ spacers, 2" RB body lift, 34x10.5 Swamper LTBs, WolphisWorks Sliders and bumpers, 400,000 mi.
Silver_Truck is offline
Old 02-02-2006, 05:55 PM   #62 (permalink)
Mr. Bob's Avatar
get them both!!!! hehehehe... then you will out wheel all your friends!!!
__________________
Hilux Surf emblem
Mr. Bob is offline
Old 02-02-2006, 05:59 PM   #63 (permalink)
Quote:
This is what I thought originally too, but In the front, I am guessing that I would never even feel it at all. I am always in 2wd, unless I go wheeling, which is when I will need it. Makes perfect sense to me, because in NJ I get into some hairy situations on the road, and in parking lots, a lot of sharp turns, and quick acceleration. I am still thinking tht the front is the best way to go.
__________________
Jason
njttora.com
JHupp is offline
Old 02-02-2006, 06:38 PM   #64 (permalink)
TEPUI's Avatar
Quote:
Lock the rear first, you may realize you never needed to lock the front to begin with.
My $0.02
__________________
'00 トヨタ 4Runner VZN185
'97 トヨタ Land Cruiser Prado RZJ90 SOLD!
Get your トヨタ TOYOTA T-Shirts, Hats, Stickers here!
TEPUI is offline
Old 02-02-2006, 07:29 PM   #65 (permalink)
damn, well if this isnt one of the most confusing descisions ever!, TEPUI, didnt you say you had a lockright in the rear and you hated it?? It doesnt even matter to me if I don't get as much off-road gain, some is better than what I have now, especially for $200, and I really really really don't want it to act weird on road, at all, like I said, in Jersey, I don't think some of the stuff I have been hearing will work. Any gain offorad like I said is worth it to me for $200, I just don't want to feel it on road.
__________________
Jason
njttora.com
JHupp is offline
Old 02-02-2006, 07:30 PM   #66 (permalink)
but (from what I've heard from everyone with one) you WILL feel the one in the front even in 2wd. The general consensus from almost everyone is to lock the rear first and to avoid things other then selectable lockers up front unless you're going to be wheelin it alot and spend the majority of your time off the pavement.
__________________
-Geoff
Old 02-02-2006, 07:35 PM   #67 (permalink)
Jeffires's Avatar
Send a message via AIM to Jeffires
I have lockright in the rear- for what I do, it is ALL I need. I will get a selectable in the front when I can afford it. A Lockright in the rear is easy to drive with on pavement.
__________________
-Jeff-
'91 4WD P/U 3VZE A340H , 197K
K&N air ] Optima ] Flex-a-Lite fan ] FloPro exhaust ] ISR Mod ] Warn M8000 ] Powertrax lockers ] Swaybar Discos ] KC Lighting ] Premier MP3 - Pioneer highs/mids - RF DVC 12/ RF 360a² ] Garmin GPSMap60C
Photo Album
MySpace
La Nouvelle-Orléans
'da Ragin Cajun
Jeffires is offline
Old 02-02-2006, 07:48 PM   #68 (permalink)
amorphous's Avatar
seriously with ADD, i'd reconsider doing the front and do the rear first.
I know of ZERO people with a front locker and ADD (other than ARBs) Sounds like trouble to me.
Contrary to what the Aussie site says, I've been told by countless peeps with more real experience than I, that the rear is where you want to start...and it's more transparent for DD
Find someone - anyone - any vehicle with a rear locker - ride with them - or see if they'll let you drive their truck - you'll see it's not a big deal.
I live in the city, my 4runner is my DD (my ONLY vehicle) - rear locker rocks, just keep your foot out of it and learn when/how it locks/unlocks
__________________
98 4runner sr5
Old 02-02-2006, 07:50 PM   #69 (permalink)
Ok, I'm gonna call the guy that sold it to me tomorrow, and ak him what he suggests. It seems that most of the people that says it rides rough, have a manual. Mine is auto, so I'm hoping that if I do lock the back it will ride smother. I always though that if you put one up front you wouldnt be able to notice it unless the truck was in 4wd, unless I am mistaken. I'm also going to ask him his suggestions, and post what I hear for your verification. Thanks again for being so patient with me here, I know most of you must be sick of this thread and my indecisiveness by now. Thanks,
Jason
__________________
Jason
njttora.com
JHupp is offline
Old 02-02-2006, 07:56 PM   #70 (permalink)
amorphous's Avatar
I drove Cherry Hill, DC, Philly and NYC traffic this summer - with the locker - with mud terrains. With the Soft Locker it was cool - totally manageable- But, you ARE going to feel it with any full time locker. AND you will notice off road - you'll crawl where you used to have to mash it to make it up stuff.
If you want "zero drive vibe" save your duckets for the ARB (or maybe OX will come out with one soon?)
....just remember to keep your U joints full of grease!
__________________
98 4runner sr5
Old 02-02-2006, 08:20 PM   #71 (permalink)
JamesD's Avatar
Simple solution. If you off-road alot, put the locker in the rear. If you off-road every now and then and you need the extra traction a couple of times, put it in the front. So how much you off road a month/year? You got to ask yourself this. My opinion on what you are describing, I would put the locker in the front.
James
__________________
New Tacome V6 transfer case http://www.yotatech.com/f107/sale-br.../#post50755569
Various Toyota truck/4Runner switches for sale http://www.yotatech.com/f109/various...trucks-148139/
JamesD is offline
Old 02-02-2006, 08:23 PM   #72 (permalink)
Quote:
James
This was my newest plan, but a few people were saying that you will still feel it in the front. I offroad once every other month. I would like to put it in the front, but like I said, I do not want to feel it on road in 2wd.
__________________
Jason
njttora.com
JHupp is offline
Old 02-02-2006, 08:40 PM   #73 (permalink)
The way I understand our drivetrains, with ADD front drive system our CV's, and diff's are always spinning. Both in 4wd and 2wd. The 4wd engages in the transfer case with auto hubs. So this would mean that a front full time locker would have the negative streetable effects all the time. The only way that this would not be the case is if the hubs were converted to manual. (which would cost more than doing an ARB locker) With manual hubs in the off setting the cv's do not spin which also means that the diff will not spin unless in 4wd.
All this aside the front drivetrain is not nearly as strong as the rear. A locker puts way more stress on the parts and I would rather slip a bit in the front and get a good bite in the rear than break in the front while slipping in the rear.
__________________
Eric
2001 4Runner with stuff:
http://www.ultimateyota.com/index.ph...6&topic=1098.0
ecchamberlin is offline
Old 02-02-2006, 08:50 PM   #74 (permalink)
JamesD's Avatar
You WILL NOT FEEL IT IN THE FRONT if you have MANUAL HUBS!! The axles shafts are not spinning when the hubs are unlocked! I don't know why so many people have a hard time with this. The ADD with spin the passenger axleshaft but not the drivers intermediate shaft, at all times when in 2wd.
James
__________________
JamesD is offline
Old 02-02-2006, 08:53 PM   #75 (permalink)
amorphous's Avatar
Eric- you hit the nail on the head.
Aaron
__________________
98 4runner sr5
Tags
activation, cable, converting, locker, trd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
MTs on a daily driver?? s_wall98 Tires & Wheels 22 06-08-2007 09:19 PM
locker on daily driver? yotakid825 86-95 Trucks & 4Runners 27 03-02-2007 12:05 PM
My new topless daily driver ....... WT Off Topic Talk 13 03-13-2006 11:33 AM
My New Daily Driver 4x4 JuttyShabango Off Topic Talk 22 10-23-2005 12:58 PM
new daily driver KevyWevy Off Topic Talk 2 09-14-2005 12:36 AM
2009 InternetBrands, Inc.
