Just mounted my tranny cooler (pics)
I've kind of been all over my truck for the last week but I've finally gotten something mounted. My Hayden tranny cooler. I didn't like the idea of some the less sturdy mounting options available so I fabbed some brackets out of alum. and bolted it in (with metric hardware). I cant plumb it yet as my tranny is on the ground. I used two of the factory bolts and had to drill two holes as well. I moved my horn over next to the other one as it was in the way.[IMG][/IMG] [IMG][/IMG] [IMG][/IMG]
The way you have it mounted is far from ideal. With both the input and output on the bottom the fluid will hardly fill the cooler and will stay mostly at the very bottom. Rotating it 90 degrees either way (or 180) would help. Looks good though!
Iceman4193
07-15-2015 04:48 PM
jon.r
07-11-2015 03:34 PM
