installing camburg arms, some problems
Old 05-15-2007, 08:52 AM
neliconcept's Avatar
Im having problems, for one my current tundra coils and top outs are so tall that it makes the balljoint hit the coil, i read through one thread that they used a tie rod fork to jam it into the balljoint, im puttin no camburg arms and i have dhoe extended coilovers im putting on later on. I have removed castle nut and cotter pin, but i cant get the arm free from the stud.
Any suggestions? I have beaten the stud to death, beaten up on the arm, jacked the lower arm up to about level and it still wouldnt come free.
any ideas?
Old 05-15-2007, 09:32 AM
stud is out, the upper arm is free
now how the hell do i get the long bolt out to get the arm off?
and how do i use these forks to get the balljoints off the spindles?
edit: bent back inner fender lining to get the incredibly huge bolt out.
now its on to ball joints, get the arms secure and do the other side.
Old 05-15-2007, 10:10 AM
and how the heck do i use this tool?
Old 05-15-2007, 01:05 PM
guess nobody has ideas on what to do with my Balljoint
Old 05-15-2007, 01:09 PM
1styota4X4's Avatar
i dont have a 3rd gen i have a second so it was easy for me....but from what i can see it looks like you need to have the ball joints pressed in and out...
see if there is a c clip around the top of the ball joint below or at the rubber boot if there is take it off and try to beat it out
Autozone rents a ball joint press
Old 05-15-2007, 06:06 PM
going to get this pin out to take the rest of the boot off and c clip will come out then i guess ill hammer it out afterwards. Fresh set of mind tomorrow morning, bright and early and ill let everyone know how it goes.
Old 05-15-2007, 09:29 PM
Albuquerque Jim's Avatar
Yes, the upper ball joint is pressed into the spindle. There is a retainer clip under the boot.
IIRC, the slug (shown in one of your photos) also has to be pressed into the spindle to accept the uni-ball.
While replacing my ball joint, I did not have good luck with a rented hand press from Autozone. IMO, these should be done with an actual hydraulic press.
The tool you show is called a pickle fork. It is used to remove the tapered end of a joint from it's base, commonly used for tie-rod ends; not these type of ball joints.
ALSO: when you re-install the long bolt for the UCA make sure you tighten to specs. I had one of those back out on me.
Old 05-16-2007, 06:21 AM
i have yet to get a press, im going to try and get one but however most on TTORA said it could be done by just hammering out with the C clip not in place. Well that hasnt happened as i beat the crap out of it and it hasnt budged a mm.
Old 05-16-2007, 09:23 AM
BruceTS's Avatar
I made a press...... I know Total Chaos sell a tool to remove them as well.
Old 05-16-2007, 09:30 AM
broke my thumb, cant really do much without my thumb so im having it towed to my moms cousins shop.
Old 05-16-2007, 09:31 AM
04 Rocko Taco's Avatar
you broke your thumb in the last three hours???
WTF did you do?
Old 05-16-2007, 11:10 AM
WTF did you do?
sledge hammer
thats all i have to say
Old 05-16-2007, 06:05 PM
4runnin2's Avatar
This was a funny thread.
Use a balljoint press tool and it will come right out. Good luck with the thumb, Oh and the Runner also!
Post up the pics when you get it done.
Old 05-16-2007, 07:42 PM
One_96TR4's Avatar
WOW...that was unexpected. Hilarious but unexpected. Good luck with the thumb.
Old 05-16-2007, 08:40 PM
colsoncj's Avatar
Might as well post up some pics of the thumb....
Old 05-17-2007, 05:59 AM
Rock Slide's Avatar
sledge hammer
Ouch!
Was this how you felt:
Old 05-17-2007, 06:05 AM
MillerPKA's Avatar
i don't think smiley faces come close to breaking your thumb with a sledge hammer.
x3 on the post-op pics. and hell, why not the thumb haha
Old 05-17-2007, 06:17 AM
Rock Slide's Avatar
Apparently, you did not watch them long enough...their heads blow up they're so angry!
take a joke
Old 05-17-2007, 06:32 AM
MillerPKA's Avatar
i saw that, i was just saying it probably felt worse than that
take a rebuttal
Old 05-17-2007, 06:42 AM
Rock Slide's Avatar
Well yeah, I'm sure it felt worse than that...I'm just fooling around w/ Blake. Anyway, back on subject.
Blake, any new updates on the 4Runner?
Quick Reply: installing camburg arms, some problems
