Improving range of keyless entry
Old 06-21-2004, 10:20 PM
jimrockford's Avatar
Question Improving range of keyless entry
My keyless entry transmitter (RS3000) has about a 15 foot range. Does anyone have any ideas for increasing the range, besides replacing it with an aftermarket unit?
I had an Ultra Start Remote Starter on my '91 4Runner. They advertised a 1200 foot range-and meant it. 15 feet is pathetic. Would new batteries make much of a difference?
Old 06-21-2004, 10:26 PM
anthraciterunner's Avatar
yeah...point the remote up under your chin. It works really well. I swear. I wonder if I have any tumors?
Old 06-21-2004, 10:35 PM
96LtdYota's Avatar
i agree with the up under the chin shot... it helps by atleast 75 feet
Old 06-21-2004, 10:41 PM
Bob_98SR5's Avatar
jim,
i've tried just about everything. the range on the rs3000 simply sucks ass. two things I tried:
- physically soldered FM stereo antenna wire and ran it along the length of the entire 4runner driver's side. increased range by...eh...20-30 feet
- soldered a 20 (or 22?) awg wire to the diversity (love that name) antenna that is located on the passeger side rear cargo window. its still like that. range increase of about 20 feet.
the best thing i've found is to keep that battery fresh and use the chin method. i've thought too about somehow connecting hte receiver wire to the taco whip antenna but i just gave up. maybe in the future.
...or maybe you can run w/ that idea and let us know how it goes?
bob
Old 06-21-2004, 11:17 PM
BajaRunner's Avatar
Wow, I never knew about the under the chin trick. What the heck ... that is so weird. Turns your brain into a transmitter, or what?
Old 06-21-2004, 11:19 PM
96LtdYota's Avatar
exactly.. no leads to cancerous growth, so im cool with it
Old 06-22-2004, 05:28 AM
SLC Punk's Avatar
I have tried the same thing as Bob and have had no success. Now i just look like a dork and point the remote to my chin to arm/disarm my alarm. :pat:
Old 06-22-2004, 05:44 AM
bamachem's Avatar
change the battery. when my batt gets low, it only works from 15-20' away. when it's new, i can get 40-50'.
Old 06-22-2004, 06:59 AM
Mad Chemist's Avatar
How the hell does pointing it at your chin increase the range? If it is focusing the radiowaves, you'd have just as good results by taking your free hand and cupping it behind the transmitter making a "dish" to focus it at the vehicle....
Old 06-22-2004, 07:57 AM
PoBoy's Avatar
...but that would look stupid.
Dont know if that actually works as good or not...but the chin thing definitely works and is easy to do.
Old 06-22-2004, 08:20 AM
Bud
Bud's Avatar
The chin thing does work on clifford/cobra alarms on my older vehicles but not on my newer tacoma.
I did a search and came up with this
Old 06-22-2004, 06:21 PM
BruceTS's Avatar
I just touch mine to my cheek bone, it turns your body into a extended antenna, that's why it works......
Old 06-22-2004, 06:25 PM
AgRunner06's Avatar
Sorry for the quick question. I've got the TDS alarm and was wondering if I will have to reprogram it if I change the battery. I've lost the instructions so I guess I would have to make a trip to the dealer if it needs to be reprogrammed.
Thanks
Old 06-22-2004, 07:06 PM
96LtdYota's Avatar
haha
"The key and the body act like the two plates of a capacitor separated by an electrical insulator. When an electric charge flows into or out of one of the plates, the electrostatic effect drives a similar charge into or out of the other. Although no charge actually crosses the insulator, a current appears to flow for a while until the capacitor is fully charged. Applying a varying current to one plate means that the capacitor never gets fully charged and a current appears to flow indefinitely through the second plate."
Old 06-22-2004, 08:22 PM
Guest
4RUNR's Avatar
Just opened the keychain transmitter and there does not seem to be an antenna in it. Not even on the circuit board, except for some tiny wire wound thingy. There's plenty of space, soldering on a piece of wire inside should help the distance.
Somebody should do a write-up on which body part or orifice gets the maximum range
Old 06-22-2004, 08:33 PM
Rugby10
Guest
Posts: n/a
Good Article Bud. That phenomena was always strange to me. So I just press the remote to my and let it rip?
Old 06-22-2004, 08:39 PM
And I thought anthraciterunner was just being a wise ass. But, I'll be darned, it does seem to work.
EDIT: Well, except when trying to amaze and befuddle my kids. Naturally, the range was actually lower when I showed them. Maybe I pressed the button too many times to show it wouldn't work from the range I was at.
Old 06-22-2004, 08:45 PM
I'm a little interested in this technique. My diversity antenna is disconnected due to the installation of an aftermarket head unit. Where is the stock antenna located for the RS3000 and how hard is it to access? 20 feet is 20 feet.
Old 06-22-2004, 10:14 PM
BajaRunner's Avatar
So I just tried the chin thing today...all day.
Didn't work!
I still have to be within 5-8 feet of my 4Runner to get it to work...and I just put in a new battery 2 weeks ago.
Old 06-22-2004, 10:34 PM
Rugby10
Guest
Posts: n/a
Didn't work!
Try my method. Its called the thing, and it works. Let it rip at 10ft, 100ft, or 500ft it doesn't matter. Guaranteed to work!
Quick Reply: Improving range of keyless entry
