"Idle Air Control" valve questions - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-27-2003, 01:48 PM   #1 (permalink)
AgRunner06's Avatar
Send a message via AIM to AgRunner06
I'm trying to diagnose my idle problem. You can read about it here.
Here's my questions:
1. Is the IAC the same thing as the "air valve" in my Haynes manual?
2. What does the IAC do?
3. Where is it located?
4. How can I test it?
5. Could it be my problem?
Sorry about the number of questions. I just want to get an idea of what the problem might be before I take the truck into the dealership next week.
Thanks a lot.
__________________
"I'm your huckleberry." - Doc Holiday
- '93 4runner - Sold!
Current Ride - 2001 Chevrolet Silverado 1500 ext.cab, pewter, 5.3L, 3.42s, fully loaded, 68K miles.
FREE ROCKET!!!!
AgRunner06 is offline
Old 04-27-2003, 10:49 PM   #2 (permalink)
hmmm....
well its attached to the thottle body
could be causing some problems
it works electrically ( well it does on the 5vz )
it changes the amount of air flowing through the throttle very slightly and only at idle to retain a constant idle speed.
to chek if its working, start the truck and then unplug the IAC-- the engine should stall and get a check engine light. If it still idles the same then its probably bad. other things to check are
EGR valve
timing chain tensioner.... ( i had funky idling on my 90 because it was broken and i never knew )
tim
Duffdog is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
22r carb stalls at idle after accidentally "grounding" out the Tach signal... out" mikedog 95.5-2004 Tacomas & 96-2002 4Runners 6 07-13-2009 07:26 AM
anyone do a writeup on cleaning the IAC (idle air control) valve? Amir904 General Vehicle Related Topics (Non Year Related) 22 10-10-2006 08:56 AM
Air Lift "Ride Control" These things rock!! he he MDNT TOY 95.5-2004 Tacomas & 96-2002 4Runners 7 04-28-2005 08:08 AM
Spidertrax Lower Control Arms "updated" sschaefer3 Offroad Tech 7 09-30-2003 08:30 AM
idle control valve sskusc 95.5-2004 Tacomas & 96-2002 4Runners 3 09-26-2003 11:15 AM
2009 InternetBrands, Inc.
