How often do you use ECT PWR??
Old 07-14-2009, 05:05 PM
omgodzilla's Avatar
How often do you use the feature and when?
Does it make a big difference when driving on the highway??
Old 07-14-2009, 05:34 PM
Lumpy's Avatar
I could be wrong I have only used it once or twice. I believe it just changes when the tranny shifts. When you turn it on she'll rev higher before hitting the next in line...My opinion it just uses more gas. But like I said I have not really messed with it yet.
Old 07-14-2009, 06:04 PM
bgmac's Avatar
Mine is always on! I live in the mountains, so it helps me out quite a bit.
Old 07-14-2009, 07:30 PM
TEPUI's Avatar
I use it when wheeling on dunes and once in a while on the highway...
Old 07-15-2009, 05:49 AM
pfdaxe's Avatar
I use it when I tow
Old 07-15-2009, 06:11 AM
Mtn Mike's Avatar
I never use it. Of course I drive like a granny 90% of the time.
IMHO, ECT uses more gas and results in more wear and tear on everthing.
When I tow, I turn off overdrive and go slow
Old 07-15-2009, 06:26 AM
MillerPKA's Avatar
since upping tire sizes i've started running it all the time. especially since i'm not doing my gears at the moment, 35s can be a little overbearing on 4.10s, but since i live on coastal georgia flatlands it isn't really an issue. but i do like the higher shift pattern for my driving styles. if you're close to stock keep it off unless you feel you need it
Old 07-15-2009, 09:23 AM
BT17R's Avatar
Originally Posted by pfdaxe
I use it when I tow
That's the one time when PWR shouldn't be used. The reason is that it allows (besides raising shift points about 500 rpm) torque converter slip for added power but also adds heat. Strap on a trailer and it can shorten tranny life. ECON for towing, PWR the rest of the time, shift manually if more rpm's are needed.
Old 07-15-2009, 09:31 AM
HazMat's Avatar
I always had mine on in the 95.5 2.7L auto. I just liked the green light on the dash. Never really noticed a difference in gas mpg or speed. It was always a dog.
Old 07-15-2009, 05:36 PM
sharrack's Avatar
Never...........I'm at the gas pump way too much as it is !
KS
Old 07-15-2009, 07:16 PM
24x4runnersport's Avatar
i always leave it on, it seemed to help out on gas? ill try leaving it off for the next 2 weeks.
Old 07-16-2009, 01:28 AM
96743runner's Avatar
I only leave mine on when going up hills. It does seem to give some extra power, due to the higher rpm's and shifting patterns. I just hope that it's not shortening the life of my tranny! 0_0
Old 07-16-2009, 06:10 AM
Kletzenklueffer's Avatar
I've used mine requently over the past 1.8 years (69,000 miles). When I don't use it and drive normal, I get between 19-20mpg. When I don't use it and drive aggressive, I get 19 mpg. When I do use it and drive normal, I get 19mpg. When I drive aggressive with it on, I get 18-19mpg.
I mainly use it when driving faster than the flow of traffic or when I'm driving on the freeway at high speed.Simply put, when I need more control over my shift points (which amounts to keeping the engine in the prime rpm range. Seems the 3.4 has the most power around 3,500 rpms. you can really feel the benifit of the 24 valve.
My truck has stock gearing and 265 75's.
Old 07-16-2009, 06:42 AM
SWPERIC's Avatar
since i put in my 4.88s i dont need either when i tow on 33s
Old 07-16-2009, 07:36 AM
The Ruckus's Avatar
I use it for pulling out into traffic, that's about it. I monkied around with it for a while when I first bought my runner, and it dinged by gas mileage by about 1.5-2 mpg over 4-5 tanks.
Longbed 90
03-11-2019 12:38 PM
camel_65@hotmail.com
10-03-2018 06:11 AM
Longbed 90
10-19-2015 11:05 AM
Boomer8404
09-24-2015 01:12 PM
Boomer8404
09-20-2015 06:15 PM
Quick Reply: How often do you use ECT PWR??
