How much Of my caliper can i take off of here w/o problems? (PIC)
This is where i'm rubbing
http://www.mustangmods.com/data/2913/untitled.jpg
How much can i get away w/grinding there?
thanks so much guys!
Grinding
Most of the rubbing I've seen has been on the left side of that picture on the caliper and on the outside, not in the spot that you circled, which appears to almost be on the inside of that contour and not the outside or is it some of both. That particular caliper didn't look like it had been rubbed much to me. If you are worried about grinding that much, just do the spacers. I probably shaved about 1/32" to a 1/16" off my calipers on another set of rims, but like I said, it was on a different spot. I did the same thing in the same spot as on mine on another friend's taco, as it was the rims I had that rubbed on mine that I had sold him!
the1998sr5
15
07-14-2020 08:35 PM
jerusry
10-19-2015 05:28 PM
09-04-2015 09:27 AM
rushw
07-18-2015 01:46 PM
jon.r
07-11-2015 03:34 PM
