How much differential fluid?
Old 07-20-2004, 07:05 PM
Pretacopower's Avatar
Hey guys, I just took apart my differential and had to drain it....how much gear oil do I put back in? I filled it w/2 quarts....is that enough?
Old 07-20-2004, 07:31 PM
bulldog-yota's Avatar
Most diffs you fill till just below the filler hole, when it is mounted and the vehicle level. If it is the rear diff, 3qts sound about right so you might need more.
Old 07-20-2004, 07:35 PM
Yeah, its the rear. I just read Bob's write-up and it says 2.6 quarts needed for the rear.....I'll go 3 to be safe. Now if I can only figure out how to get the stripped bolt off
Thanks for the reply!
Old 07-20-2004, 08:00 PM
jimbo74's Avatar
is it the bolt head thats stripped? if it is, try hammering on a 12 point socket in the next size smaller than what it should be.. and using a breaker bar... this normally works...
Old 07-20-2004, 10:48 PM
Yeah, its the bolt head. I'll give that a try tomorrow, thanks!
Old 07-20-2004, 11:31 PM
Bob_98SR5's Avatar
pretaco,
that info is in the back of your owners manual. dont go by my writeup info b/c its a different vehicle. but i think 3 quarts should be plenty. as others have suggested, park on a level surface and pump in the juice until it starts to seep out. and remember, take off the fill plug FIRST and then the drain plug last.
bob
Old 07-21-2004, 02:17 AM
Bigkahuna808's Avatar
I did almost 3 in my read diff.
ladybugRC
458
08-21-2020 10:41 AM
zanzabar0
10-11-2015 02:56 AM
voiddweller
10-02-2015 07:47 AM
bradahman
10-01-2015 09:24 AM
Odin
09-26-2015 06:56 PM
Quick Reply: How much differential fluid?
