| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#26 (permalink) | |||||
#27 (permalink) |
I used a flex end GearWrench on top & a pipe wrench on the metal dust cover. The GearWrench allows an allen key to tighten the top if you are installing Bilsteins. Big pain in the butt!!!
Paul
__________________
Gone, but not forgotten: 1996 4X4 4Runner LTD. Purchased used 5-08, 120K. Now has 265/75 16 Terra Grapplers, Performance Products springs, Bilsteins. Cupholder Mod. 2001 Tundra, V8, 4x4, Xtra cab, Limited, TRD Offroad. PP springs, Bilsteins, Snugtop shell. Owned 0-112k mi. 1992 4Runner, V6, 4x4, 5spd, SR5, PP springs, Bilsteins. Owned 0-219k mi. 1988 Pickup Xtra cab, I4, 4x4, 5spd, SR5, Ranchos, rear shackles, shell. Owned 0-122k mi. |
#28 (permalink) |
Yep, i broke that mount, and now the sway is totally gone. The front is going off sometime soon.
__________________
97 4runner, 2.7 5speed 4wd, 5.29, 33 horns armor locked lifted heavy SOB broken front and rear swaybars My Profile.. |
#29 (permalink) | |
Quote:
__________________
2000 4Runner V-6 3.4L FI 5VZ-FE, 5-spd manual, NGK plugs/wires, Amsoil: filter/engine oil 5w-30, tranmission/transfer case 75w-90 GL-4, rear diff 80w-90 GL-5, front 75w-90 GL-5, Trekmasters/OME 890 in the rear, Centric disc rotors w/ Hawk LTS pads, slowly upgrading seized, stripped or broken, impossible access to hard-to-reach places, discovering I don't have the tool/part needed to finish the job, in the middle of the job....PRICELESS & worth it all once achieved! |
#30 (permalink) |
[quote=kmcaprice14;50867477] skip all the steps... just go straight to cutting it off...As for torquing the nuts, just hand tight using a small socket wrench with a deep socket... QUOTE]
Well, it was 1130PM when I had finally finished removal/installation. The fact that you can't see the top shock mount practically had me feeling my whole way through, so it didn't matter whether I had sun or not, screw it. I'm stubborn and decided to go against the popular recommendation of destructive removals and got me some Craftsman strap wrenches. Low and behold...made it all possible to take off the old POS without damaging the housing. Someone earlier on this post 'wedged' one of the wrenches...that's what I did with the strap wrench against the muffler on the passenger side and the fuel tank on the opposite. Miracles do happen Worked so well that when I did the next rear side, I didn't use as much PB prior and still found it easier to break the seized nutcase.Torquing the top nut, uh, yah, couldn't . Took a 3/8" breaker bar with a crow's foot attachment and with the other hand used a cresent wrench to grip that super small stud - slow as hell.
__________________
2000 4Runner V-6 3.4L FI 5VZ-FE, 5-spd manual, NGK plugs/wires, Amsoil: filter/engine oil 5w-30, tranmission/transfer case 75w-90 GL-4, rear diff 80w-90 GL-5, front 75w-90 GL-5, Trekmasters/OME 890 in the rear, Centric disc rotors w/ Hawk LTS pads, slowly upgrading seized, stripped or broken, impossible access to hard-to-reach places, discovering I don't have the tool/part needed to finish the job, in the middle of the job....PRICELESS & worth it all once achieved! Last edited by 75w90mantraN; 07-08-2008 at 11:13 PM. |
#31 (permalink) | |
Quote:
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires. 2004 Camry LE - stock (and will stay that way) 1993 4Runner has been sold |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Top shock bolt not reuseable (front shocks) | aaronk | 86-95 Trucks & 4Runners | 5 | 02-10-2008 08:58 AM |
| Removable Top Bolts? | PioneerPete | 86-95 Trucks & 4Runners | 12 | 10-02-2007 09:39 AM |
| 3vze top end rebuild (head bolts) | Desert Rat | 86-95 Trucks & 4Runners | 10 | 01-01-2006 09:24 AM |
| flatbed and shock rear shock mount | 934rnr | The Fab Shop | 28 | 07-22-2005 09:49 AM |
| How many bolts do you leave in for a 1st Gen Top? | gohawks | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 05-17-2005 07:57 AM |
