Highlander upgrades...
Originally Posted by bamachem
Get a black V6 Limited with AWD. Get some gunmetal 17" sequoia wheels off of ebay and wrap them with some dueler AT revos. Tint the windows, and MAYBE do up to a 1" coil lift just to clear the tires better. That's it...
In that case some 18's from a new Landcruiser would look pretty cool too (with stock size Landcruiser tires, I think 275/70/18?)
Don't forget the stereo upgrade as well
Highlander wheel wells are SMALL. Stock land cruiser tires will never fit. No amount of SANE coil spacer is gonna fit anything on a highlander. My mom has an RX300 and to be honest, after looking under it I would be afraid to put 31's on it...even for street use. Besides that, with the AWD, they are pretty much dogs and bigger tires would make them worse.
Just remember, it it basically a Camry, can the tranmission handle the bigger tires? Why kill the gas milage? No offense, but it is not like the Highlander can go off road.
#25
#27
Originally Posted by WolfpackTLC
Ok, ok, ok... now I've got her on a 4Runner idea... used, but still an 01 or newer... but she wants TWO WHEEL DRIVE!!! ARRRGH!!!
J
J
#29
If she has her mind set on the HL, then I'd give it a rally-look (rockcrawling-look would not be believable, obviously) because of the low ground clearance. First, replace the mudguards with some long, colored mud flaps. Second, get a new set of white or bronze rims (or keep the stock alloys) and mounted on any snow tires, which gives an somewhat affect of "mud tires". Third, mount some oversized driving lamps on the front bumpers. And finally (optional), put some window deflectors and a windshield band. That's it! Simple but effective.
#30
If you are going to get the Highlander(Camry), then just do exterior mods, like rims (18's, if it were me 20's), tint, lighting upgrades (tail lights, fogs). Also, interior mods like in-dash tv, tv's in the headrest. See if you can fit a camry supercarger into that engine, the engine is the same as the camry. Look into headers, exhaust and intake. If you can do all of the engine upgrades, you might be looking at close to 300hp. Pretty cool for an AWD camry, which I happen to like. If you get a 4Runner, well, you know what to do and what can be done. If not, just look at the threads.
#31
she definetly needs to get a 4runner, that way we can get her intoxicated one night and put some spring spacers in without her knowing, then upgrade the tires to some 32s or something
#34
Originally Posted by Praufet
you definately need to wait and get the highlander hybrid
#35
If it gets anywhere near the range it claims (600+ miles per tank) it's definitely worth it because it has the efficiency (with rising gas prices it is important) without sacrificing power (270hp). Granted, it's not as efficient as other hybrids, however, it has three times as much horsepower and is just as, if not more, efficient than a 4 cylinder. Can't argue with that.
#36
most of the reason people don't get the epa mileage is because of varying road conditions, gas quality and driving style, but like havic said, if it gets anywhere near 600 and has 270 hp I'm sold. Also seats 7.
#38
Unless you plan on keeping the Highlander for more than 5 or 6 years, don't waste your money on the Hybrid. If you don't keep it for at least this long, you're losing more money than if you bought the regular Highlander. The difference in fuel cost does not offset the difference in price of the vehicle for quite an amount of time. Plus, a new Highlander is getting around 30 mpg's right now as it is, at least my cousin's new v6 is.
rushw
07-18-2015 01:46 PM
