Here's how i did the rear diff breather...
Old 03-01-2007, 01:44 PM
rocktown's Avatar
I noticed alot of people who have done the mod have removed the rubber ring around the gas tank filler tube and either clamped or zip tied the breather to the filler tube. I did it a little differently. First i removed the plastic piece in the fender well that covers the filler tube. Next i opened up the gas door and using a drill in reverse, i burned a 1/4" hole through the rubber surround. I then stuck the barbed end of the breather through the little hole in the rubber surround, and connected the 5/16" fuel hose to it from inside the fender (kind of a pain) and clamped it. So basically, the rubber surround gets pinched in between the breather and the fuel hose and it stays in place pretty solidly. Then i followed through with installing the union in place of the breather on the axle, and hooked the other end of the fuel hose up leaving plenty of slack for when i do my lift. Wont have to do this mod twice.
remove this piece:
run the hose up along the filler tube:
hook the hose up to the breather:
and enjoy:
Deckplate mod is coming up next
Old 03-01-2007, 01:46 PM
Elton's Avatar
looks easy any pics of the diff
Old 03-01-2007, 01:50 PM
rocktown's Avatar
sorry no pics of the diff, that part is no sweat. The biggest pain was getting out the plastic clips that hold that plastic piece in the fenderwell.
Old 03-01-2007, 01:55 PM
Elton's Avatar
ok ...the deckplate mod is great too
Old 03-01-2007, 02:22 PM
INFINITY's Avatar
looks perfect this is exactly how it came on my 80. good job
Old 03-01-2007, 02:29 PM
20005spd's Avatar
i did the same thing for my diff breather mod. the only thing i learned from your pics, and i will be using this idea is clamping the breather top behind the rubber gas thingy. this way it wont get in the way of the gas cap. thnx for the info.
Old 03-01-2007, 02:33 PM
04 Rocko Taco's Avatar
Thats great, clean look, and seems easy enough, you'll love the deckplate, also try the ISR mod.
Old 03-01-2007, 02:35 PM
Elton's Avatar
dont forgot to get a trueflow filter from jason b too
Old 03-01-2007, 02:38 PM
Chapman88SR5's Avatar
Has anyone done this on a first gen?
polo451
13
11-20-2016 07:49 PM
jerusry
10-19-2015 05:28 PM
Daneums
08-20-2015 05:36 AM
jaretstuff
08-04-2015 02:08 PM
scottyg486
07-19-2015 05:34 PM
Quick Reply: Here's how i did the rear diff breather...
