HELP! Can someone help me identify an ignition wire? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-30-2003, 11:52 AM   #1 (permalink)
I'm putting in a Gentex Compass Mirror and it says to use only an ignition wire for power. (Other power wires are on continuously and would drain the battery.)
PS - I've checked my manual, but I couldn't find anything that would help.
__________________
2004 4Runner SE w/ V8 4WD
35% tint, WeatherFlector vent visors, Sport Bumper Trim, Valor exhaust tip,
JDM Tails, "Canadian" Hood Deflector, & other minor mods.
wv4runner is offline
Old 11-30-2003, 04:48 PM   #2 (permalink)
Guest
Send a message via AIM to fourunnabilly
there are a few ways you could locate an ignition wire. one would be to look at the fuse box inside the vehicle and link the fuse to its wire on the other end. another way would be to tap into the IG wire running into you alternator. if you look on your alternator, the IG wire will be clearly labeled in a diagram, that is the ignition wire. you could splice into that anywhere along the line...i think mine was yellow w/ a green stripe, but i cant remember for sure. a very easy way to test if you have found the an ignition wire is to turn the key to the start position, but do not start the vehicle. touch any sort of power tester (ie - screwdriver shaped probe with a light inside and a groung wire running out of it) to the wire with the key in this position, and you should light up...then turn the key off to make sure the light goes off with the key. You'll be able to figure is out no prob...hit back if you need any more clarification.
Billy
fourunnabilly is offline
Old 12-01-2003, 05:52 AM   #3 (permalink)
Very helpful, brother Billy. Thanks.
__________________
Old 12-01-2003, 06:03 AM   #4 (permalink)
Cebby's Avatar
Send a message via AIM to Cebby
Quote:
DO NOT USE A TEST LIGHT. This is a great way to cook the electronics on modern vehicles. Invest in a multimeter so you don't damage your vehicle. I've even heard of airbags being deployed by poking around under the dash with a test light. You've got a $30,000+ vehicle. Invest in a $30 meter.
__________________
UZswap.com
A site dedicated to sharing info for swapping the Toyota/
Lexus UZ (V8) engines into Toyota Trucks and 4Runners.
My 4Runner
1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys,
low lift, hacked fenders, tubbed firewall, custom armor
TOOLandFAB.com
A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion
Cebby is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
can you identify this wire? duck trapper General Electrical & Lighting Related Topics 5 02-10-2007 05:55 PM
ignition coil ground wire weakyota91 General Electrical & Lighting Related Topics 0 01-08-2007 07:51 PM
Anyone have a 2000 Tacoma Ignition Wire Diagram? Poopshute 95.5-2004 Tacomas & 96-2002 4Runners 6 03-03-2005 08:42 PM
Ignition Wire for 03 4runner timber725 95.5-2004 Tacomas & 96-2002 4Runners 3 12-31-2004 11:06 AM
Need help ASAP - Ignition wire jacksonpt 95.5-2004 Tacomas & 96-2002 4Runners 21 06-29-2003 08:57 AM
2009 InternetBrands, Inc.
