heater core replacement in first gen
Old 03-14-2004, 03:45 PM
wifesaysimadumbass's Avatar
if anyone has done this recently and has any wisdom they would like to impart upon a fellow toyotan, then please opine. i have never tried this so if anyone has any links or something they hit their head against the wall for. then i would like to hear about it. thanks in advance
Old 03-15-2004, 05:54 AM
turtle jim's Avatar
I'ts a lota work. I used Chilton and Haynes manuals as guides. If you have a/c, the evaporator has to come out. Start by removing the glovebox, then remove everything between you and heater core. There are no shortcuts that I could find. Just grit your teeth and take stuff out. Good Luck
Old 03-15-2004, 09:21 AM
85runner's Avatar
It sucks. You will have to tear the whole dash apart to change the heater core. It is one of the last things that come out.
Old 03-15-2004, 02:19 PM
aww crap well it has to be done so i guess i will just have to do it. is an ac recharge neccesary or do you have to take out the condenser or just move it over.
Old 03-15-2004, 06:39 PM
85runner's Avatar
If I remember correctly, you can leave the condensor and the box its in attached to the firewall. The heater core should slide upward and out.
Old 03-15-2004, 06:48 PM
turtle jim's Avatar
I think that a/c part under, and behind the glovebox is the evaporater and the condenser is in front of the radiator.
I don't think it would be possible to get the heater core out of my 85 truck, without removing the evaporater. 134 recharge shouldn't be much. With summer comin, it isn't such a bad idea. Just another bullet to bite.
Old 03-15-2004, 07:16 PM
hey thanks for the help guys i really appreciate it
Old 03-15-2004, 07:52 PM
Del
Del's Avatar
Anyone have any ideas for doing the same on a 2nd gen, or am I stuck taking the dash apart also? There's something blocking the hot fluid from getting through core. I can hear the trickling as I accelerate, but it's usually not very warm (thankfully Toyota put in the floor heater under the center console).
Maybe if not replacing it, is there a way to force whatever's blocking the fluid out? I've already tried using the hose to force water through, but it didn't work. I'm stuck here.
mskalmus
05-28-2017 07:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
tpd143
07-07-2015 09:06 AM
Steezy96yota
07-06-2015 10:00 AM
coryc85
07-06-2015 04:07 AM
Quick Reply: heater core replacement in first gen
