Heater??? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-09-2003, 01:11 PM   #1 (permalink)
Send a message via AIM to Brad
Heater???
I know this is a stupid question, but what goes out when the heater is not real warm? Is it the heater or something else?? I'll have the temp on hot and it gets luke warm at best.
Stupid, I know but any help would be greatly appreciated.
__________________
Brad
97 Taco extra cab.
Brad is offline
Old 02-09-2003, 01:14 PM   #2 (permalink)
rchavis's Avatar
Check you engine temp gage. If it's low then your thermostat is staying open and your engine is not reaching it's normal operating temperature. It could also be that the thermostat that is in there, is one that is too low, like 160. It should be at least 180 degrees.
__________________
Amsoil Dealer
92 SR5 V-6 Bilstein shocks and PP springs. Daystar bushings, Mag-light mod. K&N air filter. Amsoil. CB. Firestik antenna, Scanner. Magnaflow catback exhaust, Car-sound cat-convertor. Pro-fit holder. Steering stablizer. PIAA 1400 Fog lights. Sylvania Silverstars, PIAA bulbs in dome light and corners, Sears Die Hard Platinum. Silblade wipers. Flex-a-lite electric fan. Flamm Freeway Blaster Horn Kit.
rchavis is offline
Old 02-09-2003, 01:27 PM   #3 (permalink)
PhxTRDRunner's Avatar
Send a message via AIM to PhxTRDRunner Send a message via Yahoo to PhxTRDRunner
If its not the thermostat, It's the heater core. Kind of like a radiator for heat....usually under passenger dash on most cars.
__________________
'00 4runner *Sold*
'94 Supra 6spd tt
'05 Tacoma Double Cab 4wd TRD Offroad
PhxTRDRunner is offline
Old 02-09-2003, 02:04 PM   #4 (permalink)
jx94148's Avatar
Send a message via Yahoo to jx94148
Low coolant level will cause this to. With the engine cool, open the radiator cap and fill if you cant see the coolant.
With engine hot, feel the heater hoses for temp. Cool hoses = low fluid.
I read somewhere that the heater core will go into a bypass mode when its blocked. Coolant will flow through through the hoses and make them warm still but not through the main part of the core. IIRC.
jx94148 is offline
Old 02-09-2003, 06:42 PM   #5 (permalink)
I had the same problem you did when i bought my tacoma
the heater wasnt really warm, but the thermostat indicated correct temperature right!
well-- just go to the dealer and get a new "heater control valve" under the hood attached to the firewall, these go bad and dont let any coolant into the heater core. I changed mine and it fixed everything.
good luck
Tim
Duffdog is offline
Old 02-09-2003, 07:46 PM   #6 (permalink)
1Runner's Avatar
When a heater core goes bad (leaking) you will either have a wet spot on the pass. floor up high, near the kick panel.... or you get a greasy residue all over the inside of your windshield. (anti-freeze) I've had this happen. I also had the heater control valve go bad.... oddly enough, both of those probs happened on my Dodge Daytona. My 4Runner has an incredible heater. I can get it so warm inside, that my wife will turn the heat DOWN!
__________________
2002 Tacoma double cab. 4X4
TRD package, rear locker. Imperial Jade Mica.
Stock, stock, stock. It will have to stay that way for a while. (sigh)
Hey!! I got some husky liners!!!
1Runner is offline
Old 02-02-2005, 07:27 PM   #7 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
Wanted to bring this thread BTT for the current heating probs.
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
No heater fan kt19 86-95 Trucks & 4Runners 14 01-08-2009 02:57 PM
temp/heater? j 86-95 Trucks & 4Runners 3 01-17-2007 07:01 PM
heater problems john c Early Land Cruisers 9 12-08-2005 01:27 PM
Heater. Help! JeyDee 95.5-2004 Tacomas & 96-2002 4Runners 4 02-03-2005 06:43 PM
Aux heater terky 95.5-2004 Tacomas & 96-2002 4Runners 3 05-29-2004 12:27 PM
2009 InternetBrands, Inc.
