Headlight Bulbs - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-30-2009, 09:23 PM   #1 (permalink)
atistang's Avatar
Headlight Bulbs
One of my headlights went out tonight. I would like it if they were slightly brighter. can anyone recommend a direct replacement bulb that is brighter than the stock bulbs? something like silver stars?
atistang is offline
Old 10-30-2009, 09:27 PM   #2 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
ive had the phillips vision plus the low beam part is slightly tinted they work for me
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
sister 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Old 10-30-2009, 09:30 PM   #3 (permalink)
muddpigg's Avatar
I did silver stars which were brighter but didn't last long. I got an H4 conversion kit off e-bay and run the ultra stars. definately better.
__________________
http://www.youtube.com/watch?v=rqtr_RvR3sY
Balljoints for sale. Open to trades and offers. http://www.yotatech.com/f11/ball-joi.../#post51278784
muddpigg is offline
Old 10-30-2009, 10:06 PM   #4 (permalink)
Tubbyfatty's Avatar
Send a message via AIM to Tubbyfatty
I run some 100/80w bulbs in my runner. They are just basic bulbs I got from knechts. they do say "off road use only" but ive never been flashed by oncoming cars. I also have some hella 700s that help on back roads.
Autozone, napa and shucks will carry street legal stuff. X2 about the sliver stars
some pics in here, http://www.yotatech.com/f116/new-hea...-bulbs-159923/ I aimed up my lights after this so the beam is much better now.
__________________
94 4runner / SR5 / 3vz-e / 5spd / 4x4 (duh) / Mudcat EXT 30x 9.5R15s / Marlin Crawler HD Clutch / ISR / Hella 700FFs 100w bulbs / 2 10'' JBL subs / ported sub box / kicker mono amp / Pioneer DEH-P490IB / sitting 1-1.5'' below factory, thanks butt sag...
Tubbyfatty is offline
Old 10-30-2009, 10:22 PM   #5 (permalink)
Built2Grind's Avatar
sylvania silverstar part number H6054 i think i paid 18 a piece, they are much brighter than my other lights, although the everyone seems to like the ebay lights
__________________
POS 3vz-e, 4x4, extra cab, SR5, 31's, glasspack, swaybarless and never going back!
Built2Grind is offline
Old 10-31-2009, 12:03 AM   #6 (permalink)
98runner210's Avatar
Quote:
I've heard you can melt a harness with those.
__________________
'98 4Runner Limited White w/ silver flares
98runner210 is offline
Old 10-31-2009, 01:25 AM   #7 (permalink)
Red3.slow's Avatar
Send a message via AIM to Red3.slow
Quote:
What are stock, 45/65?
I could see the problem with that, 4crawler has some upgrade harnesses that would be worth looking at
__________________
-Miles
-Firefighter/EMT
T.E.A
Taxed Enough Already
Red3.slow is offline
Old 10-31-2009, 06:55 AM   #8 (permalink)
john4r's Avatar
Upgrade wiring then if you want more get brighter bulbs. I saw a lot of improvement by installing heavier wire and relays for the headlights on my 98 4R. I used this http://www.rallylights.com/detail.aspx?ID=3730 wire harness and it was a 10 minute install. I found a nice pocket for the relays behind the battery. You can buy relays and wire and make your own for less $ but the quality of this kit is very good and it fit well.
I had more than 1 volt voltage drop with the stock wiring which apparently translates into about a 30% reduction in light output. I think the thing that limits the light is not the bulbs but the voltage. Once you get full power then better bulbs give better light.
My two cents anyway.
__________________
1998 Stellar Blue SR5 4Runner
4WD auto 3.4L
99 headlight swap
99 rear springs
Bilstien Shocks
john4r is offline
Old 10-31-2009, 05:30 PM   #9 (permalink)
atistang's Avatar
I went with a set of sylvania xtravision's, I'm getting ready to find out if they are any better than a stock bulb or not. they have the same wattage as what came out which was 55/60 i think
atistang is offline
Old 10-31-2009, 07:02 PM   #10 (permalink)
I have Silver Star Ultras and they work fine.
Clemsonfan15 is offline
Old 10-31-2009, 07:10 PM   #11 (permalink)
Tubbyfatty's Avatar
I know, its really not hard to upgrade the wiring harness...I have a friend that drives a 95 P.U. he runs 100/80w H4s, stock wiring, no probs.
I just upgraded mine to be safe.
__________________
Old 11-01-2009, 01:01 AM   #12 (permalink)
I'd say do the upgrade, last thing you want is to have a short or loose lights when you need them the most or risk a fire.
__________________
Old 11-01-2009, 09:07 AM   #13 (permalink)
X-AWDriver's Avatar
I have a set of the newer Ultrastars and they work fine and have bene in there for over a year;I got 2 and a half years out of my original set of regular Silverstars. If you have daytime running lights any pricey aftermarket bulb is a bad idea since they will have a much shorter lifespan.
__________________
'99 4Runner Highlander 4wd
E-locker,rear diff and deckplate mod * 265/75/16 Nitto TerraGrapplers * Yakima Load Warrior rack * clear corners/signals * Tacoma skidplate * Silverstar lamps/fogs
Alpine CDA-9831,Bazooka EL Series 250w amp,MTX 10" sub
X-AWDriver is offline
Old 11-01-2009, 09:41 AM   #14 (permalink)
INFINITY's Avatar
i got the 55w 6000k ddm ones for my pilot and going to get the raptor ones for my yota. they are freaking amazing.
http://www.ddmtuning.com/index.php?p...=102&parent=85
http://www.ddmtuning.com/index.php?p...=101&parent=85
__________________
TRAIL GEAR's CUSTOMER SERVICE IS TERRIBLE MORE LIKE A HEADACHE OR PAIN IN THE A$$ THAN A SERVICE!
-1980 toyota 4x4 - 235/85/16 bfg M/T tires, 03 tacoma wheels, onboard air, trd camshaft, 18" e-fan, weber 32/36 carb, 4.88 yukons, lockright in rear, etc
-94 xcab SAS, arb/lockright, 5.29s, 4" lift, etc...
Yota tech gallary- http://yotatech.com/gallery/showgall...ser=15173&sl=i
<---yes, that is victory blood!
INFINITY is offline
Old 11-01-2009, 08:46 PM   #15 (permalink)
atistang's Avatar
these xtra visions bulbs are great, i am more than happy with them
$23 for a set and they made a huge difference over stock. I got brighted tonight and i had my dims on, so i brighted the guy back, lol
out of probably 300 cars i have passed in the last 2 nights only one brighted me so i would say they are on the verge of being to bright.
atistang is offline
Old 11-01-2009, 09:34 PM   #16 (permalink)
muddpigg's Avatar
I was happy with the improvement they made too. I mine didn't last very long which some have also posted up, other they seems to last much longer. Perhaps its a electrical thing I don't know. I went to the H4 just to see if they were better and more options with bulbs. I got a set of cheap e-bay ones, the way I break things on the trail. Did break the plastic lense last winter, think ice water splashed on them. Went to wally world got a cheap set of glass sealed 6054 with the heat gun, exacto knife, and elbow grease put the glass lense on with no issues yet. Will see how they do in the winter extremes.
This are them when I got them
These are the conditions that the lense cracked
This is replacing them with the sealed beam lense, broke one on the first try. Still lots cheaper than round eyes or hella's
Not that I'm trying to change your mind just bragging what I did.
Ooops guys just realized what forumn this is in, so I'm outside of my 1st gen expertise but if you use the 6054's it'll work
__________________
muddpigg is offline
Old 11-01-2009, 09:36 PM   #17 (permalink)
muddpigg's Avatar
Don't you loose your high/low beam and only get one or the other?
__________________
muddpigg is offline
Old 11-01-2009, 10:25 PM   #18 (permalink)
be courteous and adjust them so that they are not blinding. You might cause an accident.
__________________
Old 11-03-2009, 05:46 AM   #19 (permalink)
atistang's Avatar
yeah i was thinking about adjustig them down just a wee bit
atistang is offline
Old 11-03-2009, 04:15 PM   #20 (permalink)
Mulkey's Avatar
Osram Night Breaker bulbs from powerbulbs.com.
http://www.powerbulbs.com/bulb_finde...id=1578&bulb=1
__________________
2K 4Runner Limited 4X4
2nd Gen TRD S/C
LT265/75/16 REVO's
OME 881/890
Mulkey is offline
Old 11-03-2009, 04:37 PM   #21 (permalink)
I also use the Silverstar ultras. I recently burned one out, and replaced it with a stock 55/60 w bulb and it sucks compared to the SS. I may try the 80/100 w Hella bulbs next. I wonder how well they will work with daytime running lights.
__________________
Why??? Because I Can !!!
My wife knows the difference between a body lift and suspension lift!!!, does yours?
96 4Runner, E-locked, TRD Tundra/ FJ80 coils, Bilstien 5125's, 285/75/16 MTR's. Lots more custom parts coming.
87 Supra 1jz 420 hp
Check out my website: www.bicperformance.com
BIC performance is offline
Old 11-03-2009, 07:08 PM   #22 (permalink)
Quote:
I just installed SilverStar Ultra's in mine. They were on sale at Advance Auto, so I said what the heck. Definately an upgrade over stock, much whiter and stronger. Compared to HID projectors though, they still suck.
Without upgrading wiring or doing anything fancy, the SS Ultra's are probably your best bet for straight plug and play. I'm sure there are other brands available on eBay, but the SS Ultra's are available everywhere and seem to be reliable.
quicksilvr is offline
Tags
1998, bulb, change, h6054, headlight, headlights, install, installation, legal, ohio, runner, silverstar, sr5, toyota, wattage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
