Guages only work when truck is warm?
Old 10-20-2008, 02:00 PM
NwRunner's Avatar
Ive started noticing that as it is getting colder in the mornings, when i fire up my truck the tach shoots to about 1200 and sticks, even if i rev it. If i rev it high it will jerk up to around 3000 and stay there even when i idle. after about 5 minutes of driving the tach starts reading smooth like normal. Also the temp guage will not move from the bottom unless i smack the guage cluster a few times, then it starts to read the right temp. The speedometer needle wobbles too, but i think thats just the cable?
The previous owner had some color changing faceplate crap installed and i think he tore into the gauge cluster to do it... where should i start to fix this?
any suggestions work!
Old 10-21-2008, 07:09 AM
EnolaGaia's Avatar
Is the aftermarket gauge overlay stuff still in place?
Those gauge overlay plates can cause binding on your gauge needles. Having to adjust the needles for clearance is a common move when installing those plates ...
the1998sr5
10-19-2016 12:48 PM
marcusSRG
06-27-2015 07:13 AM
slider417
06-22-2015 10:18 AM
gog1968
06-22-2015 05:55 AM
jmc88runner
06-18-2015 03:39 PM
Quick Reply: Guages only work when truck is warm?
