gearhead alignment question
Old Nov 17, 2004 | 12:24 PM
shiftless89's Avatar
Question gearhead alignment question
ok, after getting hit on monday (Front left corner) , I had the shop check out the alignment and structure. The truck was pulling to the left after the crash. It needed some adjustment and the front left tire was low. (frame is straight components seem tight) after the adjustment which came in on dead center! it pulls to the left still, not as bad as before. heres the big question it pulls harder to the left on take off and under hard acceleration. but hardly at all at crusing speeds?!?! any ideas
Old Nov 17, 2004 | 03:22 PM
BG_91's Avatar
Sounds like it could be torque steer--checked your motor mounts? any new noises?
Old Nov 18, 2004 | 09:58 AM
eric-the-red's Avatar
Another thing that will cause pulling on acceleration is if your rear axle is out of line, that tends to push the truck at an angle.
Old Nov 18, 2004 | 11:38 AM
Maybe I got hit harder than I thought!! I'm about to put a set of b/j spacers on the front then I'll check the rear axle out and try to re-align it again.
Motor mts seem fine. Of course It could all be in my head! but the tech also noticed it!
Old Nov 18, 2004 | 12:39 PM
fiveofeen's Avatar
radial tire pull is one of the most likely candidate. get your tires checked for belt separation etc.. or just swap the front two in your driveway if it pulls right then, you know your problem
Ernie217
Aug 14, 2015 05:25 AM
Up&Down
Aug 5, 2015 06:20 AM
makemusic116
Aug 2, 2015 05:23 PM
cgilley
Jul 25, 2015 10:55 PM
hangtown88toy
Jul 10, 2015 02:33 PM
