Frozen in gear?
Old Nov 24, 2004 | 10:28 PM
lctmjw's Avatar
Frozen in gear?
First KC snow, and my 4Runner FREEZES in "D". What's up with this? Is anyone aware of any TSB's or recalls on an issue like this?
Old Nov 24, 2004 | 10:58 PM
Schuey2002's Avatar
Have you crawled underneath your rig and checked the transmission linkage (it's on the driver's side)? Check to see if it's bent or if there is something wedged between it and the tranny..
Another thought, are you running regular or synthetic fluid in your tranny?
Old Nov 25, 2004 | 10:29 AM
lctmjw's Avatar
Nothing bent, thank goodness. It was frozen; I thawed the linkage with WD-40 and it's okay now. Has anyone else ever had this problem? Should there be a shield or cover or something over the linkage? This was a really stupid problem... Hopefully, just a freak occurance.
Old Nov 25, 2004 | 12:28 PM
User 051420's Avatar
Mine does this when I drive through deep snow. I usually just pull the shifter harder, and it goes into the gear that I tell it to. Maybe if you spray it with Boeshield while it's dry? Or some other fluid that will prevent ice?
Old Nov 25, 2004 | 08:58 PM
Schuey2002's Avatar
>>" Should there be a shield or cover or something over the linkage?"<<
Nope. Toyota doesn't put any guards on them.. There isn't one on my Taco.
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
