front of truck clanking somone help!
Old 10-29-2007, 05:37 PM
glendon's Avatar
my 1996 tacoma is clanking when i go over bumps in 4wd, what is the problem, i think its the differential? not sure and suggestions.
thank you
Old 10-30-2007, 04:53 AM
mjwalfredo's Avatar
I doubt it's your differential. Are you 100% sure that it is only when in 4 wheel drive? I would get under the truck and give your CV axles and sway bar a good shaking to see if either of those is causing the clanking. I had a bushing split on my swaybar once. That caused a nice clanking noise when I went over bumps.
Old 11-01-2007, 03:04 PM
glendon's Avatar
ill take a look and im pretty sure it only happens when im in 4wd,
thanks alot.
Old 11-02-2007, 06:30 AM
Bighead's Avatar
Have you installed a diff drop lately? I have seen guys install these and not torque the front diff mounts properly or add loctite when reassembling. These bolts can work their way loose and cause a clanking sound as the front diff rotates under load or while braking. Probably a long-shot but couldn't hurt to check...I have personally seen and fixed it.
Bamripzit
07-19-2015 01:17 PM
Bamripzit
07-13-2015 07:21 PM
PureTacoma_Tundra
PureTacoma_Tundra
06-29-2015 09:45 AM
dirtrider0129
10
06-24-2015 12:24 PM
Quick Reply: front of truck clanking somone help!
