Front Diff Fill Plug Stripped!!! :(
Make the moron that put it on so tight get it off! If you have to have a breaker bar to get it off it was put on with too much torque! Easiest way to get off the OEM hex head is a 24 or 25 mm, do not recall which it is, weld on another nut or air chisel. I cannot tell you how many OEM ones I have had to PERSUADE off.
Replace the OEM fill and drain plugs with a 10mm sunken hex head like in the picture above, get the 10mm hex socket, and be done with it. Only difference from diffs to transmissions and t cases is the washer, either steel or aluminum, depending on application.
We have both in stock on the website and the description tells what you need for what.
06-01-2021 01:51 PM
jerusry
10-19-2015 05:28 PM
