Front Cam Seal question...
Old 05-21-2006, 01:43 PM
phattey's Avatar
I took my rig into an indendant that I've used for years on Honda, Acuras, Nissans, and Toyotas. He does a good job and his pricing is little more affordable than the dealer.
Anyway, this past week they did T-belt/water pump/tensioner/thermostat/FCS/Radiator flush and refill. I opened up the hood, kinda looking things over a day or so later...and noticed something that got my attention...
Aren't the valve covers supposed to come off in order to replace the front cam seals..?? If so, then I'd suspect the shop would've also replaced the valve cover gaskets. Those aren't on my ticket, plus there's really no evidence that the covers even came off...
There's plenty of seeping oil through the valve covers in the rear, so I'm kinda surprised that wasn't mentioned or noticed and will call them in the morning, but wanted to ask here first about the covers needing to come off to replace the seals...
P
Old 06-04-2006, 08:33 PM
youngbuck's Avatar
Not sure, anyone else know? Does the valve cover need to come off to replace the front cam seals? Or did you call them phattey and find out?
Old 06-06-2006, 08:34 AM
phattey's Avatar
I haven't followed up with my wrench just yet.
I guess I'll call the dealer and get an answer...
Thought by now someone would've responded.
Hmmm...
Old 06-06-2006, 09:01 AM
snap-on's Avatar
no valve covers do not need to come off to repalce seals.
The end cap for the cam is machined to hold the cam seal, the valve cover sits ontop of the same end cap.
http://personal.utulsa.edu/~nathan-b...68cylinder.pdf
jasonty
41
12-23-2018 01:00 PM
jerusry
10-19-2015 05:28 PM
88sasturbotoy
08-11-2015 01:56 AM
Iceman4193
07-15-2015 04:48 PM
andrewtexas123
07-14-2015 04:29 AM
Quick Reply: Front Cam Seal question...
