fog lights arent working??
Old 04-30-2010, 03:29 PM
carolinarunner's Avatar
ok, my factory fog lights worked great for a long time on my 99 runner. but now theyre not!! :-/ so i tried putting in a new fuse and relay, but every fuse blows...any help??
Old 04-30-2010, 03:39 PM
Reyno's Avatar
It sounds like you have a wire that is shorting out on something. Follow the wires all the way through and make sure the sheath is in tact all the way along. Also check there are no loose strands of wire where ever there is a terminal.
Most likely to be a positive wire shorting out on the body or earth cable.
Hope this helps. Good luck.
Old 04-30-2010, 06:40 PM
y2kltdsport's Avatar
those wires like to break at the connectors, check/look closely at where the wires go into the connectors at the rear of fog light
06-01-2021 01:51 PM
Kalihi,HI
07-09-2015 04:29 PM
colinmil
07-06-2015 04:03 PM
Steezy96yota
07-06-2015 10:00 AM
wilbertd
07-06-2015 07:39 AM
Quick Reply: fog lights arent working??
