Finally got my BJ spacers installed...with pics
Old 07-06-2004, 08:43 PM
Marc P's Avatar
I have had my ball joint spacers in my backseat for months. Just installed them with one of the front end techs that I work with---
New Procomp shocks and steering stabilizer--no rubbing
My front is now a little taller than the rear with Downey HD coils
Old 07-06-2004, 08:47 PM
jimbo74's Avatar
do they make balljoint spacers for a 1985 4x2 toyota?
Old 07-06-2004, 08:56 PM
Cebby's Avatar
Do you have a pic of it sitting on flat ground?
Old 07-06-2004, 09:00 PM
Marc P's Avatar
I am not sure about the old ifs on 2wd trucks--you will need to contact SDORS and ask.
Cebby-no pics on flat ground yet...here is one from the other side on my slightly sloped driveway-
Old 07-06-2004, 09:22 PM
Cebby's Avatar
Looks good - are those 31's?
Old 07-06-2004, 09:33 PM
jimbo74's Avatar
sdors what/who is that?
Old 07-06-2004, 09:34 PM
turboale's Avatar
Holy CV angle batman!
Other than that, looking good!! Have you done the diff drop yet?
Old 07-06-2004, 09:43 PM
Marc P's Avatar
I think the diff angle is good-the fins are barely touching--plus I have manual hubs.
Old 07-07-2004, 12:46 AM
User 051420's Avatar
I second the CV alert!!! Was it on jacks? Or are the CV's normally at a 45 degree??!!?
Old 07-07-2004, 04:22 AM
mt_goat's Avatar
Looks good. How close are your tires to rubbing the UCA?
As long as you have manual hubs I think the cv's will be ok. If you go with the cv angle much flatter than that then the cv angle gets bad when the wheel is stuffed. Which would you rather have, a bad cv angle with the wheel stuffed and lots of weight and traction or a bad cv angle with the wheel in full droop with little or no weight and traction? Assuming manual hubs are unlocked on the highway of coarse.
Now you get to raise the back too. I just finshed adding 2 leaves to my spring pack to get level again. Here's my latest pic http://community.webshots.com/photo/...58716087gxwnHV
Old 07-07-2004, 04:41 AM
Marc P's Avatar
I am running General MT 31x10.5 and I have at least 1/2 inch clearance from the UCA. You also need to realize that the CV angle shown is not on level ground so it may seem more severe.
Here is my before and after shot--
before-
After-
Old 07-07-2004, 05:49 AM
mt_goat's Avatar
Here you go. http://www.sdori.com/ It is Frank's (AKA Elripster) Company. He had to change the name to SDORI because of conflicks with competition.
Did the 85s have t-bars? Maybe a picture of your UCA would help.
Old 07-07-2004, 06:16 AM
Cebby's Avatar
Mt Goat - are you running 5.5" of lift now?
Old 07-07-2004, 06:23 AM
mt_goat's Avatar
It is something like that. Plus I just put on a RB 1 inch body lift. Maybe now my 33's won't rub anymore
Old 07-07-2004, 11:06 AM
elripster's Avatar
I wish I did. I'd like to but I need to find a guinee pig in San Diego. Actually, I've been talking to a guy with a 2wd T100. As I understand it, the arms are the same. I'm going to see if I can meet up with him and take some measurements.
Frank
Old 07-07-2004, 08:52 PM
Marc P's Avatar
So I have been driving with them for a couple days now, and I think I need to put my front sway bar back on and get some discos.
Old 07-09-2004, 10:19 AM
Epic Ed's Avatar
Why? Bobbing and weaving a lil too much with the added height?
Old 07-09-2004, 10:52 AM
mt_goat's Avatar
The ball joint spacers allow you to back off the t-bar adjustment and that gives you more flex but it also gives a little more sway and lean on the turns.
Old 07-09-2004, 11:26 AM
WSU4runner's Avatar
I dont think they'll work for an 85. Arent they solid axle? Atleast I know the 4x4's are.
malteserunner
Early Land Cruisers (Build-Up Section)
89
02-09-2018 06:59 AM
09-04-2015 09:27 AM
4Runnin2000
07-29-2015 06:09 PM
terminator
07-27-2015 07:13 PM
jon.r
07-11-2015 03:34 PM
Quick Reply: Finally got my BJ spacers installed...with pics
