Factory e-locker button
Old Mar 17, 2005 | 09:35 PM
heckler's Avatar
I am trying to use the facory button with the inchworm gear kit for installing my elocker setup. The factory button normally has four wires coming out the back of it the bottom and top are for engaging the locker and the middle two are for lighting the button. When i got my button from the junk yard it did not have the wires from it . and mine has 5 prongs on the back of it and I believe that i use the bottom four but i just dont know what the top prong the fifth one is four. does anyone have a clue about what i am talking about?
Old Mar 17, 2005 | 10:26 PM
Jake94's Avatar
Yep got a clue.....But the factory switch WILL NOT work with the inferior Inchworm way of wiring. In order to use the factory switch you'll need to make an ECU using 3 5pin on/on relays. A better way to wire it IMHO.
Jake.
Old Mar 18, 2005 | 07:37 AM
heckler's Avatar
yeah i know , the basic kit that inchworm advertises will not work but they made me one you that i could use the factory switch just.
So would you enlighten me now with you answer to button problem
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
Patrick1976
Sep 15, 2015 11:33 PM
VT2LAB
Sep 10, 2015 09:36 AM
Highlander Giant
Sep 8, 2015 06:46 PM
zz_denis
Sep 6, 2015 03:43 PM
