Electrical Paranoia, 2003 Tacoma - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-28-2003, 04:43 PM   #1 (permalink)
Hi All,
We just bought a 2003 Tacoma SR5 TRD, and are getting custom tube bumpers, rocker guards, etc. done at a fabrication shop here in Colorado. We want to mount a bunch of extra light on the new bumpers
The counter man at the dealership made it sound like doing much work on the electrical system would risk a non-waranty burn of the whole computer and wiring system. Should I be this paranoic?
Also, does anyone know if there is already at least one built-in circuit for fog lights, or more?
Thanks for your help, nice forums here!
'best, Lou
loudawg88 is offline
Old 09-28-2003, 06:50 PM   #2 (permalink)
Good Times's Avatar
Send a message via AIM to Good Times
Lou:
Most likely the lights you'll add will have it's own aftermarket wiring harness. Therefore you shouldn't have any problems. The only problem that you might run into is that you'll be draining alot of power off the battery but I highly doubt that unless you're lighting an actual stadium!
If you need some major extra circuits then try getting one of these, but it's not required.
http://www.painlesswiring.com/fuseblock.htm
look at the 7 circuit ruse block.
If you're just wiring up 2-4 additional lights, then just use the wiring harness that comes with the lights and you should be fine. Just install it as the installation says and you should be fine. If you have any questions, just give us some more info on what kind of lights you're planning to install and we should be able to help you out
Good Times is offline
Old 09-28-2003, 07:57 PM   #3 (permalink)
Tacoma Dude's Avatar
Send a message via AIM to Tacoma Dude
Check out Corey's article 2nd from the bottom on this page:
http://www.yotatech.com/~corey/tech/techpage2.htm
The tech section here is REALLY cool to look through!
__________________
Peter!
2002 Tacoma
1986 4Runner
Tacoma Dude is offline
Old 09-29-2003, 06:00 AM   #4 (permalink)
Thanks! That's good info! Here is one of the more technical things we'd like to do with lighting, and don't even know if it's possible:
We're planning on tapping in to the backup light circuit and adding an extra couple of backup lights, no problem there, I assume.
But, we'd also like to be able to turn all the backup lights on from a dash switch (for attaching trailer, setting up camp, etc.) Possible to wire this way? Anyone know how?
'best, Lou
Old 09-29-2003, 11:50 AM   #5 (permalink)
__________________
Peter!
2002 Tacoma
1986 4Runner
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
2003 Tacoma rims SOAZtim The Classifieds GraveYard 1 04-23-2007 08:24 PM
RE:2003 Tacoma DRL Mr.Tee 95.5-2004 Tacomas & 96-2002 4Runners 1 09-20-2006 06:02 PM
Head Gasket Paranoia '88 4Runner gohawks 95.5-2004 Tacomas & 96-2002 4Runners 6 01-14-2005 10:43 AM
It's no wonder paranoia runs rampant among the stoned... Dr. Zhivago Off Topic Talk 1 03-25-2003 11:03 AM
2003 Tacoma Question Nuhklz Maintenance & Repair Archives 4 11-25-2002 04:06 PM
2009 InternetBrands, Inc.
