Electric (Taurus) Fan Cooling indicator
Originally posted by Robinhood150
... Your alternator is not always pulling it's peak current ability. The formula for torque of an electric motor is:
T=K x Phi x I
where T=torque, K is a machine constant, Phi is magnetic flux, I is the current in the windings.
Also, power calculations for a generator:
P=T x w
where P=power in watts, T=torque in N-m, w is angular velocity.
Since P=IV
IV=T x w
T=IV/w, and V is constant and w is constant. If the current draw goes up, the torque also goes up. This torque is transfered to the engine via the pulley, increasing gas consumption...
T=K x Phi x I
P=T x w
Since P=IV
IV=T x w
Has anyone done the fan conversion on the 3.4L. I have everything to do this swap (i.e fan, DC controller, made an aluminum shroud that mounts to the radiator). When the fan is attached to the shroud the water pump is in the way. I should have off set the fan from the water pump and I probably wouldn't have this problem. It is tight in there but I am sure it can be done. I havent heard of anyone doing this swap with the 3.4L. I am also adding a sensor to tell me the fan is turning. It should be cool when I am done, but right now it is a PITA!!!! I am also adding temp gauges under the stereo. Any help or tips will be appreciated.
Tony
Tony
Bourbonblues
12-15-2017 05:43 PM
FS[PacNorWest]: 1993 4 Runner, V6, 4wd, Auto,
AkitaDog
09-03-2015 09:01 PM
