Electric Fan with Variable Speed Controller Installed
Old 06-12-2005, 05:39 PM
dragr1's Avatar
Originally Posted by bamachem
kinda... except you don't need a two speed, you won't be using the hayden controller, and you don't have to fab up mounts...
Cool, less fabwork is right up my alley!
dragr1 is offline
Old 06-12-2005, 05:42 PM
waskillywabbit's Avatar
Let me know when you wanna have a wrenchathon. I got the tools, the space, and the air conditioning!
waskillywabbit is offline
Old 06-12-2005, 05:49 PM
dragr1's Avatar
Cool, if I bring the beer we'll be set!
dragr1 is offline
Old 06-12-2005, 05:51 PM
bamachem's Avatar
Originally Posted by dragr1
In a junkyard how would I tell the one/two speed fans apart? What years?
two speed will have 3 large wires for power. the single speed will have only tow large wires. both may have a smaller relay trip wire like the volvo fan did.
bamachem is offline
Old 06-12-2005, 05:52 PM
  #25
My family will be gone until next Saturday night...
Old 06-12-2005, 05:59 PM
  #26
dragr1's Avatar
I think this may be the Tauras Fan, looks very similar to that Volvo unit:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33600
dragr1 is offline
Old 06-12-2005, 06:00 PM
  #27
dragr1's Avatar
I couldn't even get the parts here in time w/o paying big shipping costs.
dragr1 is offline
Old 06-12-2005, 06:12 PM
  #28
bamachem's Avatar
call some local yards. they're very common and very cheap. usually only about $25-$30.
bamachem is offline
Old 06-12-2005, 06:16 PM
  #29
dragr1's Avatar
Yeah, I'm going to. I'm gonna also look in a buddy's import junkyard, he may have something that will work.
dragr1 is offline
Old 06-12-2005, 06:18 PM
  #30
bamachem's Avatar
measure your existing shroud. look at the height and width and the opening diameter. match up something w/ a large fan to nearly fill the opening w/ maybe a 2" or 3" gap. match the width as close as possible and get as much height as you can. remember that the OEM fan is offset, so it's good to get an electric fan that is also offset so it will easily match up w/ the OEM shroud.
the volvo fan is 17" tall and 24" wide and 3" deep and is stock on models V70, S60, S80, & S70
bamachem is offline
Old 06-13-2005, 07:36 PM
  #31
I was told today that if you can find a Ford Focus electric fan that it will work very well...small, light, (2) fans I believe and puts out more cfm than the Taurus. Only drawback is that the oldest model Focus is a 2000, so not many to pick from...
Old 06-14-2005, 04:02 AM
  #32
bamachem's Avatar
original post updated w/ more info and sizes of the fan that was used...
bamachem is offline
Old 06-14-2005, 05:20 AM
  #33
MTL_4runner's Avatar
Andy, very nice install on that.....I am impressed! I wouldn't have thought to "nest" the Volvo fan shroud but that is a very good solution to the problem and should give you the best airflow possible from that fan. I wonder what is the highest CFM (non-dual) OEM fan out there?
....I think even if the Focus did have higher CFM the dual design would make nesting difficult.
Again, great job!
MTL_4runner is offline
Old 06-14-2005, 06:38 AM
  #34
bamachem's Avatar
Again, great job!
THANKS!
First of all, the fan I have now in 90* heat w/ the AC on and sitting in traffic still never sees 100%. I've hooked it up directly to the battery to see how loud it was, and if I had to guess, the MOST it's seen so far is maybe 70%. I don't think a larger CFM or a dual fan is necessary. You basically would have to do MAJOR modification to the stock shroud to get it to work w/ the dual fan setup. I did ZERO changes to my stock shroud. If I wanted to go back to the mechanical fan, I wouldn't have to replace the first part and could do it in 30 min or less. It's THAT easy of a replacement.
Also, with the fan only seeing ~70% speed in harsh conditions AND the fact that it's a variable speed controller and the fact that the temp needle builds quickly and then PEGS at just under 50% and NEVER moves, it's my opinion that a dual fan or even a dual speed fan isn't needed for our setup. A simple, CHEAP, single speed taurus/sable/volvo fan will be fine.
BTW, I got my volvo fan used on ebay for $20 + $10 shipping. Nobody buys these to put on a street racer or crawler, so it's an untapped source so to speak. I've seen the prices on the dual speed taurus/sable fans go from $30 to $80 in the last 2 or so years simply due to the popularity of the electric fan swap on so many vehicles. The main thing is to get a fan that matches up w/ the diameter of the stock shroud opening well and that also has the "quiet", turbine-shaped blades and can move some air. If you find the diameter w/ the correct blade pattern, then by default it should move plenty of air for the 3.4L.
bamachem is offline
Old 06-14-2005, 12:54 PM
  #35
Guest
4RUNR's Avatar
Have an ODBII computer handy? I do. The temp gauge needle stays in the middle of the gauge, starting at around 160F. It is in the middle at 212F too, read through ODBII. Didn't try warming it up high enough to see when the needle actually starts moving past the middle. The needle isn’t indicative of cooling efficiency at all if you ask me.
4RUNR is offline
Old 06-14-2005, 01:18 PM
  #36
midiwall's Avatar
Yeah... 2nd'd. I was amazed at how little the needle moves relative to the real temp.
The only time my needle moved up from that "just short of halfway point" was when my fans had issues and I was on the way to a boilover.
midiwall is offline
Old 06-14-2005, 01:54 PM
  #37
Ganoid's Avatar
I plan on switching to one of these fan controllers in the very near future. When you guys are talking about temps and fluctuation keep in mind that the thermal sensor for the solid state fan controller is at the bottom of the radiator measuring the final water temp just before it enters the engine. I dont think there will be much in the way of temp fluctuation with this type of controller.
Ganoid is offline
Old 06-14-2005, 02:29 PM
  #38
964runner's Avatar
make it a tech writeup we need some new ones
964runner is offline
Old 06-14-2005, 03:51 PM
  #39
Robinhood150's Avatar
The only thing about the single speed taurus fans is that they're much thicker than the 2 speed taurus fans. For 2nd gen 4runners a single speed won't clear the engine.
Robinhood150 is offline
Old 06-14-2005, 05:24 PM
  #40
bamachem's Avatar
ahhhh. good point...
bamachem is offline
Quick Reply: Electric Fan with Variable Speed Controller Installed
