E-locker complete (entire axle) shipped for $460
Originally Posted by 00Runner
Steve,
Do you know which 4Runner models came with e-lockers and 4.56 gears? Was it only the 4 cylinder engines?
Originally Posted by <96 Runner>
Steve-
How sure are you that this is a 4.30?
(00 Limited)
(00 Limited)
If it's a factrory Auto from a V6 and an e-locker, it has 4.30's.
#25
Originally Posted by sschaefer3
100%, Pull the code and see.
Swapping out the whole rear axle is a fun two-man job. Very straight forward wrenching. Swapping out the IFS diff is not that hard either. BTW, I really like the 4.30s with my 265/75R16s.
(Includes electronics) - That really makes this a sweet deal. If possible, make sure you get the Dash switch, dash switch plug with pigtails, ECU, ECU plug with pigtails, and the wiring from below the rear seat all the way to the rear diff, including both of the plugs/pigtails prior to the harness that goes under the rig. That will make the wiring pretty straight forward.
#26
Pull the third and count the ring gear teeth, 43 teeth and 10 pinion teeth is a 4.30 ratio. That is what I had to do when I bought my e-locker axle with 4.30's and also the front diff. Skip the locker ecu and just get the Inchworm wiring kit and then you can run the locker in 2wd also. If you are worried about the axleshafts, use the shafts from the axle you have now-I also did this since the rear axle that I bought did not come with the axleshafts.
#27
E-locker
#28
Originally Posted by waskillywabbit
You put the e-locker in yourself Brett? How much were you out of pocket?
I now have my original front diff and rear axle with 3.90's sitting in the garage.
#29
4.30's would be a nice Ring and Pinion to have.
Here, this should help: (You find the model code on the sticker inside the driver's door)
Model Code Ratio
RZN180L-GKMSKA 3.727
RZN180L-GKMSKA 4.100 With P265/70R16
RZN180L-GKPGKA 3.727
RZN180L-GKPGKA 4.100 With P265/70R16
RZN180L-GKPSKA 3.909
RZN180L-GKPSKA 4.300 With P265/70R16
RZN180L-GKPZKA 4.100
RZN185L-GKMGKA 3.909
RZN185L-GKMGKA 4.100 With P265/70R16
RZN185L-GKMSKA 4.100
RZN185L-GKMSKA 4.556 With P265/70R16
RZN185L-GKPGKA 3.909
RZN185L-GKPGKA 4.100 With P265/70R16
RZN185L-GKPGKA 4.300 Option With P265/70R16
RZN185L-GKPSKA 4.100
RZN185L-GKPSKA 4.556 With P265/70R16
RZN185L-GKPZKA 4.100
RZN185L-GKPZKA 4.300 Option
VZN180L-GKPSKA 3.727
VZN180L-GKPSKA 4.100 With P265/70R 16
VZN180L-GKPGKA 3.727
VZN180L-GKPGKA 4.100 With P265/70R 16
VZN180L-GKPZKA 4.100
VZN185L-GKMGKA 3.909
VZN185L-GKMGKA 4.100 With P265/70R16
VZN185L-GKPGKA 3.909
VZN185L-GKPGKA 4.100 With P265/70R16
VZN185L-GKPGKA 4.300 Option
VZN185L-GKPSKA 4.100
VZN185L-GKPSKA 4.300 With P265/70R16
VZN185L-GKPZKA 4.100
VZN185L-GKPZKA 4.300 With P265/70R16
RZN185L-GKPSKA 4.100 With P265/70R16
Oh, BTW DO IT! This is an awesome deal, I did it a few weeks ago it should only take a few hours.
#30
#31
Originally Posted by Albuquerque Jim
What??? I knew you'd come around
Now 4.88's would have let you go to a 315. If you try that you'll be back in the same boat you were with the 4.10's and 285's.
Wait till you see then tomorrow, they are HUGE.
FS[PacNorWest]: Rear chromoly axle shafts
A2theK
01-10-2016 10:18 AM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
