Driveshaft Slack?
Old 10-22-2007, 06:05 PM
RunnerUp's Avatar
Driveshaft Slack?
Hey everyone, ive searched for answers, but cant find a specific answer to my problem.
sometimes when i take off from a stop light or sign, it feels like there is lag from when i press the gas and it takes off... meaning i let off the brake, then press the gas and it kind of clunks. this only takes less than a second, and i cant seem to find a rhyme or reason to why it does this
it doesnt do this everytime, and it doesnt really make a noise, its just really annoying and i dont know what it is. i just had my rear end regeared and a new diff put in it, so i dont think its that...
could my driveshaft just have extra slack in it or is this a tranny problem surfacing?
thanks in advance...
Old 10-22-2007, 06:38 PM
Crazychopstick's Avatar
I actually get this on occasion as well. A little grease in the driveshaft zerks helps it a bit, and I even went as far as replacing the U-joints, but lo and behold, the problem is still there.
Old 10-22-2007, 06:53 PM
nieuwendyk-25's Avatar
With the engine off, put the vehicle in neutral and the parking brake set, on a flat surface. Climb under the vehicle and turn the driveshafts back and forth by hand to see if you can locate the slack...I had this problem with an old Cherokee (full size) I had. Hopefully it is in the u-joints and not somewhere else in the drive train.
Old 10-22-2007, 07:27 PM
RunnerUp's Avatar
i would so go outside and do this right now, but my parking brake no longer works since the disc swap... will chucking the wheels be sufficient?
Old 10-22-2007, 07:54 PM
Yeah..that will work fine just so you don't run over yourself....the drive train will turn on its own...you can do it in park for slack too, unless it is bound up. That should tell you if it is a U-joint of drive shaft pretty quickly.
Old 10-23-2007, 04:46 AM
mjwalfredo's Avatar
I have noticed the same thing with my 4Runner as well. I am inclined to believe that the problem is in my transmission. It shifts with a thud when I get on the gas too. I guess that could still possibly be the driveshaft though. When I get some time, maybe this weekend, I plan to take off the driveshaft and run in FWD to see if that makes a difference.
Old 10-23-2007, 05:24 AM
881stGenRunner's Avatar
because of my detroit locker whenever i get on or off the gas the there is a little jolt.
Old 10-23-2007, 05:37 AM
jason191918's Avatar
could there be play in the spline for the slip joint?
Old 10-23-2007, 04:15 PM
When I had my old full size Cherokee it was in the transfercase chain...Quadratrac. It was an automatic and would clunk when it was put in gear.
Kyle-
Did you find anything on yours?
Old 10-23-2007, 04:47 PM
mjwalfredo's Avatar
Well what felt like slack in my truck is now gone after tightening the throttle cable, the transmission kickdown cable and draining/filling the transmission fluid. I also realized I had put way too much transmission fluid in the last time I drained it. Not sure which one made the difference but it was probably a combination of all 3.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
kawazx636
10-06-2021 03:03 PM
ToyotaMD
08-17-2018 10:16 PM
Hugh_Mann
09-16-2015 03:59 AM
Quick Reply: Driveshaft Slack?
