Do You Need Distilled Water For The Coolant? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-15-2007, 11:05 PM   #1 (permalink)
HI:
I remember reading an article long time ago that it is recommended to
mix anti freeze with distilled water instead of tap water. Is this necessary?
jim628 is offline
Old 05-15-2007, 11:11 PM   #2 (permalink)
neilan's Avatar
i have heard that if you live in an area with very pure water such as well water or minimal water treatment (high mineral content) that it is best to use distilled water. But i always use straight antifreeze anyway why not just do that to keep things simple?
__________________
DD: 87 4runner SR5, 31's, rebuilt engine, intake, new head, new injectors, new afm, 2.25 exhuast, header etc...
SOLD: TR: 81 sr5 pickup. 5.29's spool rear, detriot front, highsteer, 36 sx's, lifted, bobbed, cagged, 22r with header, 32/36, 261 cam, new head and rebuild.
Residing in the PNW bham 360
neilan is offline
Old 05-15-2007, 11:18 PM   #3 (permalink)
deserttoy84's Avatar
Send a message via AIM to deserttoy84
straight antifreeze causing overheating unless you live in canada or somthing wheres it always frozen. You dont HAVE to run distilled but it is perferable.
__________________
1984 toyota sr5 4x4
22r w/ weber 32/36
Pro comp 4" front springs & 3" rear downey spring
Home made On-board air system
V6 4.88 lock rites F & R
Bilstein 7100 reservoir shocks
deserttoy84 is offline
Old 05-15-2007, 11:21 PM   #4 (permalink)
Spanky's Avatar
Send a message via MSN to Spanky Send a message via Yahoo to Spanky
straight anti-freeze?? yikes!!
__________________
1992 Toyota Truck 22re 5 Spd (194K and going!)
Magnaflow Highflow Cat
Flowmaster 40 Series Muffler
2.25" Pipes
K&N Air Filter
Airbox Mod, AFM Mod,
2" Body Lift
BFG All Terrain 31x10.50's
American Racing "Chamber" Wheels 15x8
Spanky is offline
Old 05-16-2007, 02:08 AM   #5 (permalink)
jct61765's Avatar
I use distilled, why take chances. For the couple of bucks its worth it.
__________________
2002 4runner sport 4X4
87,000 and counting
2007 Camry LE
I'm bitterly clinging to Guns and Religion" (and I'll keep the rest of the constitution too)
jct61765 is offline
Old 05-16-2007, 05:06 AM   #6 (permalink)
Beartracker's Avatar
Over the past 30 years I have run straight antifreeze and never had a engine overheat or any heater problems and I do not live in Canada but in the mids west where it is 100 in the summer and 0 in the winter.
I do not run straight antifreeze in my 2.7 Tacoma only because when I last flushed it I ran short so I just added rain water.
The problem with radiators is not caused by the water you use alone but also by how often you flush the system. Every two years is a good idea for a healthy system including being good for the water pump and thermostat. Mike
__________________
2001 Tacoma SR5 4x4 , step side, 2.7 , extended cab, Auto. Mobile 1 syn 5w30 , Valvoline 75-90 syn in front and rear diffs and transfer case. Factory 16" wheels ,31" Wild Country TXR 265/75/R16, Aluminum Betterbuilt bed tool box, CB , 55W Halogen light mounted on tool box for back up, Elbow air box mod, 2 500 Hella running lights, Nissan Clinometers/Altimiter custom mounted on dash with red back lights.Red dome and mapp light.
Beartracker is offline
Old 05-16-2007, 05:21 AM   #7 (permalink)
mt_goat's Avatar
Yes, use distilled water. It will keep your cooling system in much better shape. Why would you want to introduce all those minerals to the system? The tap water will increase mineral deposits which over time can clog passages. Tap water can also cause electrolysis between dissimilar metals. Electrolysis does things like eat holes in radiators and freeze plugs and can even contribute to head gasket failure. Keep in mind the head and block are dissimilar metals. There is a reason the Toyota engineers say to use distilled water only in your owners manual.
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Old 05-16-2007, 07:06 AM   #8 (permalink)
k_southman's Avatar
Water transfers heat better then straight antifreeze so a 50/50 mix is best.
Even in Canada a 50/50 mix is typically used. This will provide protection to -40 (it gets close, but not that cold in the winter!)
__________________
2000 4Runner Limited 120K, ELocker, OME shocks and springs
1991 4Runner V6 Sr5, 2" Susp. Lift, 33" BFG MT
k_southman is offline
Old 05-16-2007, 07:10 AM   #9 (permalink)
Roadrunner's Avatar
You can even buy coolant that's premixed with water 50/50.
__________________
Ian
2001 4Runner SR5 4x4 - An Evolving Expedition and Search and Rescue Response Vehicle
TJM, XD-9000 Winch, Badland Sliders, SAW/OME Lift, 33" BFG TA KOs, Homemade CO2 Set-up, Optima Blue Top, Cobra 75 WX ST, Icom V8000, Icom IC-F121, 1.0" 4Crawler BL, Hayden Tranny Cooler, Wilderness Rack w/Hella 550s, Snorkeled and Trail Armor by BudBuilt.
TLCA #14,082
SAR Field Team Leader - Shenandoah Mountain Rescue Group
Roadrunner is offline
Old 05-16-2007, 07:14 AM   #10 (permalink)
mt_goat's Avatar
Distilled water is only about a $1/gal. You can even any you have leftover.
__________________
~Dale~
mt_goat is offline
Old 05-16-2007, 10:45 AM   #11 (permalink)
Quote:
i'm a big fan of the prestone quick fill, already a 50/50 mix, just poor it in
__________________
Joe
1997 4runner limited
SS #1 lift, 1" 4crawler bl, Black Chrome fzj80 wheels, 295-75r16 Nitto Terra Grappler, Hella 500 driving lights, deckplate, satoshi grille, extended rear diff breather, and a bunch of other junk.
rocktown is offline
Old 05-16-2007, 11:39 AM   #12 (permalink)
Yota Tony's Avatar
Canada isn't that cold you crack pots.
Don't use stright anti freeze. 50/50 mix with distilled water is the best way to go.
__________________
Anthony
93 ZJ - Stockish (HP D60 Front, 14 Bolt Rear, 231/D300 Crawl Box...awaiting 40" tires)
Ballistic Crap Missile
ILikeMud.net
Mallcrawlin.com
SOTRA
Yota Tony is offline
Old 05-16-2007, 01:08 PM   #13 (permalink)
jrallan26's Avatar
I use distilled water with a mixture of coolant. For added benefit I use a can of Redline "Water Wetter".
__________________
My Profile
jrallan26 is offline
Old 05-16-2007, 01:39 PM   #14 (permalink)
mt_goat's Avatar
Quote:
Water Wetter...brilliant! Yeah I'm running a bottle too.
__________________
~Dale~
mt_goat is offline
Old 05-16-2007, 02:00 PM   #15 (permalink)
OK you guy's. What the hell is water wetter? Sounds like a big scam to me. Isn't water already wet????, lol. Mike
__________________
Old 05-16-2007, 02:10 PM   #16 (permalink)
mt_goat's Avatar
Quote:
http://e30m3performance.com/myths/mo...ter_wetter.htm
__________________
~Dale~
mt_goat is offline
Old 05-16-2007, 02:11 PM   #17 (permalink)
dias_ryan's Avatar
No way dude.. water wetter rocks.. haha
just kidding.
Do you guys Flush your own systems?
out of curiousity... How do you do that? Do you run the hose in at the top and let the bottom drain? and if so? where do you let it drain?? Ground?
I can't seem to think of an environmentally friendly way to do that?
__________________
1996 Ext Cab Tacoma
V6, 5 spd
16" MT Classic Rims, 265x75 BFG AT tires
TJM T15 steel bumper
dias_ryan is offline
Old 05-16-2007, 03:49 PM   #18 (permalink)
Bennito's Avatar
check your local ordinances. Last place I lived said to flush your antifreeze down the toilet. In small doses the bugs at the sewage treatment plant LOVE it..
__________________
Ben - 97 sr5 - full of win.
Bennito is offline
Old 05-16-2007, 04:56 PM   #19 (permalink)
jrallan26's Avatar
I found out about water wetter through karting..
__________________
My Profile
Old 05-16-2007, 05:50 PM   #20 (permalink)
Now I see!,Lol. I will be nice and make no comment. Like my Mother always said....If you don't have anything good to say then don't say anything at all.
Thanks for the link to the info Mt. Goat, Mike
__________________
Old 05-16-2007, 06:08 PM   #21 (permalink)
4Crawler's Avatar
I use deionized water in mine most of the time, less expensive than distilled and works just as well. I also add Water Wetter along with the Toyota Red coolant, ~50:50 mix.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 05-16-2007, 11:45 PM   #22 (permalink)
Nismo Convert's Avatar
Send a message via AIM to Nismo Convert Send a message via MSN to Nismo Convert
You know if you have a dehumidifier in your house that water coming from it is demineralized right? I empty the dehumidifier once a week, and I have enough demineralized water for years, I'll sell you some for a few bucks a gallon is you like .
Nismo Convert is offline
Old 05-17-2007, 04:40 PM   #23 (permalink)
dlbrunner's Avatar
Deionized is BAD!!! De Ionized water is very agressive. DeIonized or RO (reverse osmosis) water will corrode stainless steel over time, a lot of RO drinking water plants are going to fiberglass vessels because the stainless ones are not holding up. There are a lot of free radicals in RO water which are very reactive. Also the pH of RO water is lower (more acidic) than distilled or tap water.
With RO plants we see a lot of elevated lead and copper levels after the install. Also Iron, aluminum and nickel will leach into solution. In an engine where the solution is under high temperatures and pressure you will see accelerated corrosion.
Distilled is the best way to go.
__________________
Duncan
Current: 95 4X4 SR5 V6, Yakima tracks/rack installed. Aisin hubs. Sonoran Steel IFS Truss. Cobra CB(finally!)
Desired: 66 FJ45 shorty
EX's: 89 4X4 V6 Downey'd
72 FJ40 W 350/SM465 powertrax, "Billy"
dlbrunner is offline
Old 05-18-2007, 07:35 AM   #24 (permalink)
tom_mag's Avatar
I've never heard that before but it sounds like you know what your talking about. I use water from the water softener or from the culligan tap.
In my Buick i use straight water and water wetter. In the Toyota, Toyota anti-freeze 50/50 or 60/40 water/antifreeze. Water cools better than anti-freeze.
__________________
Tom
1971 Buick Riviera w/7.5L V8 The quintessential American car.
2000 4runner w/2.7 I4 The fuel efficient parts chaser.
tom_mag is offline
Old 05-18-2007, 11:02 AM   #25 (permalink)
Bennito's Avatar
Lets work backwards.
Commercial antifreezes have various anti-scaling and anti-corrosion chemicals, in addition to ethylene glycol, to keep your cooling system in tip-top shape. Because of those chemicals, there is actually a broad range of water quality standards that your engine cooling system can tolerate. If you follow the directions and mix 50/50 antifreeze with distilled water from the store, you'll be in good shape.
Why a 50/50 mix? For most of contintal america a 50/50 mix will provide adequate freeze protection in winter. 50/50 is easy for the end user to mix. 70% antifreeze / 30% antifreeze will have the largest change in freezing point depression. While water has a higher specific heat than EG, I'm not willing to make comment on if water cools better (especially wtih antifreeze additives that might increase heat transfer coefficient).
Lastly - Deionized vs RO vs distilled. These are all methods of purifying water. none of them is a level of purity. While they separate/purify water based on different principles, at the level of purity we're talking about they can be considered siilar. Why? Because we're trying to get the big chunks out of our tap water for use in an engnine heavily treated with water treatment chemicals (the antifreeze). You may have also noticed that the distilled water you buy in the store is lacking on quality standards as well. indeed its not a well regulated industry. Furthermore, output water quality is a function of input water quality. That is, I've had chance to work with water purification systems in phoenix and colorado springs. Reverse osmosis product water (2 stage) from phoenix tapwater results in colorado tapwater.
Ultimately, this implies that people in various parts of the country may get away with using tap water in their coolant. But why risk it.
sorry for the gaps in knowledge/oversights. only had a few mins to write this.
__________________
Bennito is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Coolant or water in the vacuum lines(metal tubes) for '85 22RE EGR pcmentor 84-85 Trucks & 4Runners 2 11-10-2006 08:07 AM
coolant/water temperature gauge help typical8o8 95.5-2004 Tacomas & 96-2002 4Runners 13 10-06-2006 06:32 PM
22re losing coolant, coolant tank bubbling shwuz 86-95 Trucks & 4Runners 15 07-25-2006 07:57 PM
coolant in water..again... toywheelin05 General Vehicle Related Topics (Non Year Related) 5 03-12-2006 11:55 AM
My coolant overflow is spewing coolant? any suggestions on what it might be? wimpywade94 Maintenance & Repair Archives 8 07-19-2003 11:50 AM
2009 InternetBrands, Inc.
