diff question
Old Jan 28, 2004 | 02:53 PM
runnerboy97's Avatar
diff question
my buddy blew the ring gear in his 97 taco, i assume its a 8.4". we found a 3rd out of a 95 truck to replace it with, are they the same? it has the same ratio and all.
Old Jan 28, 2004 | 03:16 PM
toy283's Avatar
If it's a Tacoma, it will swap in (unless it's an e-locker). If it is not a Tacoma, it will not swap in as it is an 8" diff.
Old Jan 28, 2004 | 03:19 PM
Flygtenstein's Avatar
Toyota rear ends from 79-95
Toyota front axles from 79-85
Land Cruiser 80's Series fronts from 91-97
4-Runners rear axles from 96-2002
Taco rear axles with e-lockers not sure on the year
All of the above are 8" Toyota diffs. Excluding e-locker housing mods, one will bolt into the other.
If the Taco had a locker, the new third has to be e-locked, but it could be one from the 95 runner.
If it was not e-locked, then you cannot use the third from the 95 runner since 8.4" does not equal 8"
Old Jan 28, 2004 | 03:36 PM
thanks for the clarification. i jsut wasnt sure when they axels changed to 8.4.
so an 8" diff from 95 will not fit in an 8.4", correct?
Old Jan 28, 2004 | 04:06 PM
toy283's Avatar
Correct.
Old Jan 28, 2004 | 09:30 PM
suv's Avatar
suv
You need a 3rd from a non-TRD 4x4 taco or t100. E-lockers weren't available for Tacos in '97.
jaretstuff
Aug 4, 2015 02:08 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
scottyg486
Jul 19, 2015 05:34 PM
