YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 08-17-2007, 01:50 PM   #1 (permalink)
Personal Sales Rating: (0)
AppleJack's Avatar
Diff Dropped yet still vibrates
I have '99 4runner with a 2.5 in Pro comp poly lift. I dropped the diff 3/4 of an inch and my cv's still vibrate between 55-65 mph, no leakage though. Next week I'm going on a 600 mile back country trip and was wondering if this vibration shouldn't be too concerning or should it? It's only been lifted about a month and a half, If that matters.
AppleJack is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 08-17-2007, 01:52 PM   #2 (permalink)
how do you know its the cv's?
could be driveshaft or wheel alignment.
__________________
1999 4runner Limited 4x4 - E Locker - SS #1.51 Kit - King 2.5" Coilovers - 285 Mickey Thompson Baja MTZ's - Stubbs Sliders - Alpine 9883 Deck - Shrockworks Front Bumper
TRDrunner is offline
Old 08-17-2007, 01:55 PM   #3 (permalink)
Bighead's Avatar
When was the last time you had your wheels balanced? Every time I have had an issue with a vibration at that speed it's been a balance problem.
__________________
2004 Land Cruiser -- OME/Slee Suspension | Slee Dual Battery | Slee Armor (Front, Rear, Sides and Belly) | Nitto TG 285/75-16 | ARB Drawers
Bighead is offline
Old 08-17-2007, 04:56 PM   #4 (permalink)
Godzilla's Avatar
if you havent had a wheel alignment since the lift, then that woulld be the best place to start.
Godzilla is offline
Old 08-19-2007, 10:20 AM   #5 (permalink)
Threadstarter [OP]
AppleJack's Avatar
I had the alignment done, however that doesn't mean it was done right! I suppose it could be the tires but I don't think so because it started right after it was lifted. I expected some cv vibration and installed a drop kit which helped some but didn't completely eliminate it, but I'm not sure if they do. Do they?
Old 08-19-2007, 11:02 AM   #6 (permalink)
it should because it lowers the cv angles more towards stock.
__________________
Old 08-19-2007, 02:41 PM   #7 (permalink)
Personal Sales Rating: (1)
rocket's Avatar
It would be a good idea to replace your steering rack bushings too...
http://www.wheelersoffroad.com/96024runner.htm
__________________
'96-'02
gone: '92
rocket is offline
Old 08-19-2007, 03:41 PM   #8 (permalink)
Threadstarter [OP]
AppleJack's Avatar
Should I have dropped it more than 3/4 of an inch?
Old 08-19-2007, 05:05 PM   #9 (permalink)
frodin1's Avatar
What did you end up using to drop the diff? I had a Daystar 2.5 inch spacer lift on my rig for a long time and never had problem 1 with vibration. It's most likely something else.
__________________
Pioneer HU, Audiobahn 10.100watt Sub, Sirius, JBL comp speakers in all four doors, Cobra NWWXST CB W, Quadwrap, Wolo Air horn, K&N FIPK,Tokico Trekmasters,Tundra TRDs, Revtec spacers w/extended studs,Energy bushings on steering rack /front swaybar,SS front diff. drop kit w/skid plate mod,OME 890 Rears with OEM LC Tokicos,Ebrake ext. bracket, BFG AT/KO's, ProComp 1078 Alloys, Magnaflow SS muffler, Hayden 1678 Tranny Cooler, 85watt Amber fogs, 7 Way R/V jack for the boat.
frodin1 is offline
Old 08-20-2007, 05:13 AM   #10 (permalink)
Threadstarter [OP]
AppleJack's Avatar
Thanks for the help. I was wonderin' this though, my brother has a rough country 2.5 in spacer lift on his 2000 Taco and his cv angles are quite a bit less steep than mine. Am I comparing apples to oranges here? Basically the front ends are the same and the lifts are the same except for the brand. Were '99 4runners made differently?
Old 08-20-2007, 05:48 AM   #11 (permalink)
Threadstarter [OP]
AppleJack's Avatar
Okay I just went over to my brother's to take some measurements and this is what I have found. His Taco sits at 12 5/8 at the back of his skid plate and mine is 14 1/4. He is running 32 in Pro Comp A/T's and I am running 265/75/16
BFG A/T's (roughly 32inches) his tires have a little more tread than mine but not too much and his coils look more compressed than mine. Is there anyone with a stock '99 4runner with 265/75/16 BFG's to measure against? I just don't see how there could be an inch + difference between them.
Old 08-20-2007, 09:14 AM   #12 (permalink)
gpcollen1's Avatar
Did you get the printout of the alignment or take a look at teh computer screens. If the just straightened out your ride and did not check the other adjustments then that may be it.
Wheel balance is the number one source of vibration...
__________________
'99 SR5 Sport - Desert Dune: AirRaid MIT, OEM Air Filter, Toyo 265/75/16 ATs, Deckplate, PP Springs and Bilsteins, Cheapo nerf bars, Injector replacement impending
gpcollen1 is offline
Old 08-20-2007, 07:01 PM   #13 (permalink)
Threadstarter [OP]
AppleJack's Avatar
I got the print out on the alignment job although I must admit I'm not sure what to make of it. Left side so many degrees right side so many degrees and so on, so again I'm not sure. I went ahead and dropped the diff another 3/8 of an inch and gave her a good run up a hill and I think it helped but to soon to tell if it's cured. So this is pretty much a 1 1/4 diff drop is there draw backs to that?
I used the ALL PRO 3/4 in. and this evening I added some washers.
Old 08-20-2007, 08:13 PM   #14 (permalink)
1999runner's Avatar
99s are taller
1999runner is offline
Old 08-21-2007, 04:35 AM   #15 (permalink)
Threadstarter [OP]
AppleJack's Avatar
Quote:
Originally Posted by 1999runner View Post
99s are taller
I was wondering if they were. Do you know how much taller they are?
Thanks!
Old 08-21-2007, 06:54 AM   #16 (permalink)
sschaefer3's Avatar
Quote:
Thanks!
Yeah, an entire coil wrap more.
__________________
Steve Schaefer
WWW.SonoranSteel.Com
Suspension Lift Kits * Rock Sliders * Straight Axle Conversions * 4Runner/FJC Rubicon Express Lower Links * Accessories * Daystar Products Dealer * TJM Bull Bar Dealer * Deaver Leaf Spring Dealer * Tokico & Bilstein Shock Dealer * ViAir Dealer * Total Chaos Dealer
sschaefer3 is offline
Old 08-22-2007, 07:34 PM   #17 (permalink)
Threadstarter [OP]
AppleJack's Avatar
All seems fine now but I hate doing hack jobs like stacking washers under my spacers but, oh well it's working for now. I will purchase a whole different set when I get back from my trip in Eastern Oregon this weekend.
Thanks for all yer help!
Yotatech
4WD Truck
Paid Advertisement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Engine vibrates in gear when stopped Shoretaco 95.5-2004 Tacomas & 96-2002 4Runners 11 07-04-2007 07:10 PM
'82 22r vibrates on turning off gzos510 Pre 84 Trucks 4 07-11-2006 11:33 PM
Need Help!! My 4runner vibrates. Mailry General Vehicle Related Topics (Non Year Related) 14 02-21-2006 02:33 PM
2.7 Tacoma Vibrates at MvCrash 95.5-2004 Tacomas & 96-2002 4Runners 3 01-30-2005 01:27 PM
Got New 33s'; now front vibrates!! Help! cool rob 95.5-2004 Tacomas & 96-2002 4Runners 10 07-12-2003 09:25 PM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
