| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
defrost minus A/C compressor
#2 (permalink) |
Okay, tell me this isn't the same on the 2nd gen trucks..... I drained my AC pump/lines for my OBA conversion and have been at a standstill for a month and a half. I really don't want to have a fried pump when I actually convert. From what I have *seen* on my truck... the AC is a seperate button from the rest of the controls. The defrost isn't a button but is on a slide switch. I've never felt the drain of power like I did when the AC was on. And the last time I had my climate controls pulled out, I didn't notice any wires coming from the climate control unit that would indicate that it was connected to the AC pump.
__________________
New Rig 2007 Double Cab Taco Sold 1991 300ZX Twin Turbo Stage 3+ Sold 1991 4x4 Pickup V6 5spd; 3" Rancho lift; 1.5" BJ Spacers; Rear Detroit |
#3 (permalink) | |
Guest
Quote:
Jim |
#4 (permalink) |
Cool find!
__________________
www.rimpainter.com Get your O Gasket Mod Here! My SC'd 4Runner's Profile My YouTube vids |
#5 (permalink) |
Sorry I didn't specify my vehicle, it's a 99 taco trd 3.4l . The climate controls (as well as almost every other dash control) is the same as my wife 99 camry. I've also noticed the same redundant a/c-defrost compressor action on other cars that I can't recall at the moment. The second gen trucks may not be the same. I had an 82 toyota 4x4 (that I wish I still had) and I dont think switching the duct to defrost activated the compressor pump in that rig.
#6 (permalink) |
Ya, in deforst mode on 2nd Gen's (and corresponding gen trucks), the AC does not come on automatically.
But, in 3rd Gen's (and apparently corresponding gen trucks), the AC does come on in defrost mode. (I hope that all came out right)
__________________
1995 4Runner V6 4x4 |
#7 (permalink) |
ON 2nd gens the a/c is a seperate function from the defrost. The a/c comes on the same time as the defrost on newer models because without it the windows will not clear very well with just the defroster on especially on cool rainy days. Your hot breath is what causes the windows to fog up so you need cold air to clear them. That has been my experience. They do this because the majority of people are either too lasy or too dumb to press the a/c button when their windows are fogged up.
__________________
92 4Runner SR5 V6 4X4 Skyjacker Nitro shocks, Pro-Comp steering stabilizer, clear bumper lenses, lund windjammer, OME standard coils, ISR mod, inlet pipe removed, Bushwaker Fender Flares. 2002 Tacoma Prerunner V6 Xtracab. Lund Intercepter bug guard, rear glass sunshield, Bilstein shocks on rear. 2004 Honda CRV EX stock belongs to wife. |
#8 (permalink) |
The A/C doesn't run cause you need cold air to remove fog, it runs because the condensor removes the moisture from the air.
__________________
2007 Tacoma DC 4WD TRD In Germany. Haven't been here since I got rid of the last Runner in 2005. Glad to be back in 'yota's. |
#9 (permalink) |
Guest
It's good exercise for the compressor too in the winter months. Having it sit idle 9 moths a year =
#10 (permalink) | |
Quote:
__________________
#11 (permalink) |
Not sure if this is true with all vehicles but in my previous car, there's a sequence of buttons pressed that will give you control over the a/c. No need to get behind the dash.
#12 (permalink) | |
Quote:
I've just hated having the a/c run in the defrost position as I use the defrost position often and use it mostly as a source of fresh air. Yes, I'm smart enough to turn on the a/c when the windows get foggy.
#13 (permalink) |
I don't think mine runs un my 98 4runner. Does the light light up when it comes on. There are some other reasons too i don't think it works that way either. I had the AC compressor lock up and took a few months before i replaced it and I never heard the belt squeal or anything with the defrost on. It would scream like a sun of a bitch though if I hit the AC button.
__________________
If it has tits or tires it'll give you problems. 98 4runner - SR5, 4x4, 5 speed The Probe, CJ5, G20 and Porsche are all sold. Right now everythings a 4x4 or 6x6. MRAPs, 916s, HMMWV, FMTVs and anything else with amror. |
#14 (permalink) |
My 96 Taco has a separate system, I also run mine on bi-level most of the time for heat from the defrost ports and down below from the heater ports. On "wet" days the windows will fog up unless I hit the A/C button and then they clear up pretty quick. I also agree that it's a must to turn on the A/C pump at least once a month but once a week is best to keep them from freezing up.
__________________
Lance N. Vancouver, WA 1996 Taco 3.4 - 3"Revtek, 33's 190,000+ |
| Tags |
| camry, center, cluster, finish, panel |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Header install: T-minus 24 hours and counting | rimpainter.com | 95.5-2004 Tacomas & 96-2002 4Runners | 42 | 02-03-2004 06:41 AM |
| New baby count down T-minus 6 days... | Firefyter-Emt | Off Topic Talk | 11 | 08-21-2003 01:33 AM |
| would exhaust minus headers be beneficial? | rickgoof | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 02-18-2003 03:35 PM |
