CV Boot Replacment
Old 08-16-2010, 05:02 PM
frodin1's Avatar
CV Boot Replacment
I've been searching around and read a lot about the boots comming apart after lifts on the 3rd gens. I can't seem to find what is exactly involved with putting the long travel CV boots on. Is it a total pain, or should I just keep swapping axles? Has there been a good fix for this issue?
Old 08-16-2010, 05:04 PM
PismoJoe's Avatar
You can get a diff drop or do a manual hub conversion
Old 08-16-2010, 05:12 PM
frodin1's Avatar
I've got the Sonoran diff drop. How much of a bitch is it to do the hub conversion? Is there a writeup somewhere?
Old 08-16-2010, 05:17 PM
PismoJoe's Avatar
It's a real PITA unless you are lucky and find a 4wd tacoma spindle assembly with manual locking hubs. Be sure to get ABS or non ABS spindles depending on your application if you go that route.
New, wheel hubs are $130 each, then add about $250 for bearings and seals, then you need some custom built axles (you need to put the half shafts on the ADD type axles)
Nix99 sells a kit for $575 IIRC, comes with the spindles, axles, and manual lockouts.
Here's a good write up but more in depth ones can be found with a search
http://www.4x4wire.com/toyota/review...ub_conversion/
Old 08-16-2010, 05:49 PM
frodin1's Avatar
I think I'll stick with what I got. I don't plan on dumping that kind of dough into this thing right now. Has anyone done the swap for the high angle boots?
Old 08-16-2010, 06:29 PM
Nevin's Avatar
Yes, Ive installed high angle CV boots. after tearing boots with the Revtek spacer lift I had installed. Even with the diff drop, high angle cv shafts are a problem.
Got mine from ebay for 40 bucks w/grease. no more torn boots.
Old 09-05-2010, 02:12 PM
AlexJet's Avatar
I checked this afternoon my wife's truck and found that both (left and right) sides inner boots are torn out.
I checked on-line and found several companies for CV boot replacement. Did anyone had any experience with any of those or knows anything about it?
PRECISION Part # 6467 CV Boot --- $9.55
4WD; Position: W3- Front Left Inner; W4- Front Right Inner
RAYBESTOS Part # 8168053 Professional Grade (Rebate/Promotion Available! See Promotions & Rebates Page for Details.) --- $9.79
Front; Inner; Four Wheel Drive (4X4)
BECK/ARNLEY Part # 1032843 --- $12.86
4WD; 2 required per vehicle; Front Inner
RAYBESTOS Part # 8161052 Professional Grade (Rebate/Promotion Available! See Promotions & Rebates Page for Details.) --- $17.57
Front; Inner; Four Wheel Drive (4X4); Universal Solid Boot
DORMAN Part # 614004 --- $21.79
Front Inner; Uni-Fit; 4WD
Rear Inner; Uni-Fit; 4WD
icentropy
09-16-2020 02:47 PM
mskalmus
05-28-2017 07:51 AM
BeMiceElf
10-10-2015 09:40 PM
TURBOrunnerNM
07-22-2015 11:01 AM
1994toyota
07-17-2015 03:03 AM
Quick Reply: CV Boot Replacment
