Crank Key
Old 06-21-2010, 06:41 PM
tgillespie's Avatar
Crank Key
My 4Runner took a dump today. I noticed some belt noise while driving to work today. Once there, I popped the hood to find my harmonic balancer and crank bolt practically sitting there. The key is trashed.
Whats the fix for this? I've read about the loctite fixes, but I really hate rigging stuff together. Would the harmonic balancer need replaced if it appears fine?
A new crank bolt, key and the correct torque should do the trick? Also, any luck at doing this by just removing cooling fan?
Old 06-22-2010, 05:58 AM
mt_goat's Avatar
No way can we help with the damage assessment without good pics. Hopefully your crank shaft isn't too trashed to reuse.
More info: http://www.motor.com/MAGAZINE/Articles/012007_04.html
Quote from link above:
A driver may ignore the noise, vibration and misfiring symptoms until it's way too late. By that point, the loose parts may allow the woodruff key to wear or wallow out the keyways in the crankshaft and/or crank sprocket!
217 ft-lbs is the correct torque spec for the crank bolt on the 5VZFE, not the 184 spec mentioned in some places.
Old 06-22-2010, 12:25 PM
tgillespie's Avatar
The crank snout looks and feels fine. The key is the only damaged part. $1.25 from Toyota.
Would you strongly recommend replacing the crank bolt? Threads are fine. Harmonic balancer is fine.
Slide a new key in and torque at 217 lbs?
Old 06-23-2010, 05:48 AM
mt_goat's Avatar
I really think it would be in your best interest to post up some pics of the key-ways. The first time I saw one that had this problem it was so wallowed out I thought it was suppose to be that way.
For example: does this one look ok to you or not?
Old 06-26-2010, 09:21 PM
dimitri's Avatar
Thumbs up
Originally Posted by tgillespie
Would you strongly recommend replacing the crank bolt? Threads are fine.....
I would!!! Mine looked fine too. (After it came off)...but I decided to replace it anyway
When you try to thread them back on finger tight you'll feel the difference between the old and the new.
As for the harmonic balancer "looking" fine...make sure it has no play when you put it back on. depending on how long it was being banged around before the bolt came of, it might be worn in a conical way even if you can't see it.
greasyglue
12-12-2015 12:57 PM
bvleonov
08-22-2015 11:39 PM
jmyer72
08-20-2015 07:55 AM
JHalcyonM
08-04-2015 01:19 PM
TDonkey
07-26-2015 10:14 AM
Quick Reply: Crank Key
