Coolant leak on passsenger side
I have a 98 4Runner 4WD V6 engine. I recently replaced thge water pump and timing belt and after filling the radiator with coolant, still have a leak. The leak is coming out of the lines going into the rear of the passenger area. I have the rear blower in the passneger area, and wondering what could be causing the leak to come there. I have no hot air coming out of the vents and not sure were else to look for the problem. Is this a heater core issue? I have a new WP theromstat and still getting nothing resolved. Any ideas or anyone run into this, and know what it is, would appreciate the help.
thanks guys
thanks guys
ok, well that helps alot, now where is this line? Is it the long one going from the engine area down, or the shorter piece coming into the rear passenger area? One thing I did notice is that before it goes into the cab area, there is a short piece of rubber hose between the 2 metal tubes. Is this normal or did someone try a simple fix on this?
thanks.
thanks.
probably on the water bypass outlet. its a bitch to get to. its easier if you take off your hood and use some of those really long needle nose to get to the clamps. good luck, it sucks...just did it.
I looked and yes the whole rear feeder line was rusted out. I ended up taking it all out and just capped off the hoses in the engine area. The dealership wants $100 for the 2 lines and I will have to wait to get that. Any ideas where I can pick one up cheaper. I though of running just braided hose all the way.Anyone done this or is it not recommended?
Poncho0206
07-10-2015 06:21 PM
Avenged
07-09-2015 07:55 AM
