Coil Ingiter - Your Opinion
Old 04-14-2004, 05:57 PM
SteveO's Avatar
I'm looking for another, rather a replacment coil igniter. I found that Downey sells a Jacobs 40K volt for about 30 bucks. My coil igniter is slowly dying. Its getting harder and harder to start. I ohmed it out today, and its out of spec. Anybody have some favorites that they have really liked, AND didn't cost them an arm and a leg?
Old 04-15-2004, 05:53 AM
Astralplane's Avatar
Word of caution, my ignitor ohmed out of spec per the toyota factory manual.
Dealer didn't stock item so I had to pay for it in advance.
New ignitor ohmed out exactly the same as the old one. $80 bucks down the drain.
The 1994 manual spec range is not correct.
Old 04-15-2004, 07:09 AM
SteveO's Avatar
Well, thats not a good thing, when you can't trust the Factory manual. :pat:
Old 04-15-2004, 08:58 AM
MTL_4runner's Avatar
Was your multimeter bad?
Old 04-15-2004, 09:07 AM
SteveO's Avatar
Mine is brand new.....Pretty high dollar one at that.....
Old 04-15-2004, 10:25 AM
No, I checked out every sensor, switch, coil, etc I could and the coil ignitor was the only item not in spec.
I was having a bad no horrible stumbling during start-up.
Real problem was a bad head gasket.
Old 04-16-2004, 12:43 PM
SteveO's Avatar
Once you got it running, would it run OK?
I just had my timing belt down by some "professionals", and they replaced the head gasket as well. However, the only time it has a hard time starting up, stumbling, is when its warm out and has been sitting for a while under the sun. I dunno, I just ordered a Jacobs standard replacement coil from Summit Raceing. I'm hoping this will take care of it.
Iceman4193
10-16-2015 10:50 AM
the_supernerd
10-01-2015 09:20 PM
themightykhoner
09-18-2015 02:28 AM
mojo4x420
09-16-2015 08:07 AM
Quick Reply: Coil Ingiter - Your Opinion
