| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Check engine light on '00 4Runner SR5?
#2 (permalink) |
Either take it to an autoparts store to pull the code or disconnect the negative battery cable, wait about 20-30sec., then reconnect and start the truck. See if the light comes back on...
If you bought it from a dealership, sometimes vital parts can get wet when they detail the engine bay, or even the body shine they hose it with after can screw stuff up resulting in an intermittent CEL. |
#3 (permalink) |
you mentioned you put gas, maybe you didn't tighten the gas cap enough. Double check.
#4 (permalink) |
Yeah, double check that the gas cap is on correctly. If you still get the CEL after checking, try resetting the CEL or take your rig to AutoZone and have them pull the code for you. Once you find what the code is we can help you out better.
__________________
'99 Taco PreRunner V6 3.4L
#5 (permalink) |
Double ditto on those last 2 posts...had the same problem once about 30 miles after a fill-up.
__________________
2000 4Runner SR5 4x4 Sport Mods: Crimestopper Remote Start Alarm - Deck Plate Mod - 400W Inverter - Limo Tint - K&N Air Filter - Tundra Brakes/w Ceramic Pads & PowerSlot Rotors - Hayden Trans Cooler - Goodridge SS Brake Lines 2000 4Runner LTD 4x4 - Wife's Mods: Deck Plate Mod - Tundra Brakes/w Ceramic Pads & PowerSlot Rotors - Goodridge SS Brake Lines - 400W Inverter |
#6 (permalink) |
Go to autozone or the equivalent there, they will usually pull the code for free. Post the code here.
I recently had a check engine light. It was the MAF sensor. All fixed now. Not much goes wrong with these vehicles from what I can tell. MAF's, O2 sensors
__________________
2000 4runner | 3.4L | e-locker | TJM T-15 | 305/70/16 maxxis buckshot | powder coated procomp 1069's |Lightforce 170's | Yakima Load Warrior Rack | Warn M8000 w/Viking synthetic winch rope | 4crawler 1" BL | Front:OME lift 881's w/ 1 1/4" daystar spacers + N91S shocks. Rear: OME 891's w/N86 shocks | Stubbs welding sliders | Cobra 75 WX ST w/ K40 fiberglass 2' antenna |
#7 (permalink) | |
Quote:
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#8 (permalink) |
i assume u did not puy disel in it, but was it cheap gas, if the old owner used primium nad u pu regular cheap gas it can set off a cel
__________________
2006 Tacoma 4x4 TRD Sport with 20's and 285 Goodyear Furtura's and 2 inch cornfed lift 2002 Tacoma Extra Cab V6 (SOLD) |
#9 (permalink) | |
Quote:
If you put 85 in there (which some areas still sell) then yes, you might encounter some orange light problems.
__________________
:Marko: Supercharged 98 4Runner SR5 4x4 3.4L 4" Deckplate :: TrueFlow Air Intake System :: Magnaflow 18" Muffler w/ Resonator XM Satellite Radio (Roady 2) :: Autometer Boost Gauge :: Color Keyed Spoiler TOYOTA|moving forward
#10 (permalink) | |
Quote:
#11 (permalink) |
Update all...
Thanks for all the tips. Last night I did disconnect the neg battery cable, let it sit for a few mins and then put back on. CEL went away. Drove it about 25 miles today and the light came back on. Did the neg cable unplug again...CEL off. Came back on in 20-30miles range. Drove another 15miles or so with it on and then after next start up it was off. Now it is back on! I did put 87 octane in but have no clue what the previous owner used. I'll take it to try to get the codes pulled tomorrow. Overall tho it is driving great. Thanks, Mike |
#12 (permalink) |
The Autozones here in PA will pull the code for free. Find a local joint that'll do the same and post the code. I doubt you're doing any damage to the vehicle as most of the codes are rather benign. You may or may not even notice any change in the vehicle's driveability.
Once you post the code, it could be as simple as cleaning the MAF (which is a very common CEL).
__________________
'00 SR5, Desert Dune: 4" Deckplate, Amsoil TS-115, Bilsteins, Brembo rotors w/Performance Friction pads, Fiam Highway Blasters, Sylvania Silverstars, Hella Micro DE Fog Lights w/Hella Yellow Star Lamps - SOLD 1/24/09 '08 Sport, Salsa Red: Hella Optilux fogs, Silverstar Ultra Hi beams. Pending: Borla dual catback, CAI, shocks |
#13 (permalink) | |
Quote:
spend the 25 bucks and buy an OBD 2 scanner from a parts store, used it to get this code, and keep it for the future if it runs good still,,,,I am betting O2 sensor,,or,,Evap cannister
__________________
305k MILES! 97 4Runner Khumo Road Venture MT's 285 75 16's LC wheels,Desert Dune,moonroof,safari rack,kc daylighters,3.4 Ltr. 5 spd,410s detroit ez locker, OME 891's, KYB shocks3 - 3.25 lift, Tokico,Taco springs,3 in lift in front Rev Tek spacers/top out 4Crawler diff drop, 1 in BL, 4 Runner altimeter, 2.5 in Flowmaster,high flow cat, mandrel steel air intake conical K & N. MSD DIS4,CB with 7 channel wave/weather report,4 foot firestick,Pioneer CD,30 gig IPOD. www.sfaboston.com |
#14 (permalink) |
Got a scanner...was a bit more then $25 but that's ok.
Pulled the codes. Said there were 2. One was "172" which in my book says ""System Too Rich (Bank 1)". I erased it and the CEL went out. The other code was "172 Pending" Not sure what the pending part means. I guess I'll see when the CEL comes back on. Should I do anything about the too rich code? Thanks, Mike |
#15 (permalink) |
That would be "P0172". Do a forum search. I recall this as a common CEL code but can't recall what the fix is...
__________________
#16 (permalink) | |
Quote:
Few threads for you to read on that: http://yotatech.com/search.php?searchid=1854421
__________________
#17 (permalink) |
Sounds like an easy fix. The MAF sensor is dirty and requires cleaning. I have used QD Electrical parts cleaner. You first have to remove the Maf sensor and be really careful with this thing. A couple of short bursts from the aerosol spray on the sensor, reinstall and the codes go away!!!!
#18 (permalink) |
I'm gonna try to clean the MAF today.
I've noticed a bit of a jumpy idle in the morning too so hope it solves that also. Mike |
#19 (permalink) |
Well, tried to go remove the MAF sensor and I was able to get the top screw out but the bottom bolt...the head is stripped pretty good and I can't get any type of screwdriver in there to turn it! Unless I can figure out some way to get it out I may need to take the top bolt out and just break the sensor around the screw and take the screw out w/pliers...and get a new sensor. What do they run from the dealer?
Also noticed the front clips of my air cleaner box were not clipped shut. Mike |
#20 (permalink) | |
Quote:
__________________
#21 (permalink) |
So just use a drill bit and drill thru the head of the screw? I assume go to the dealer for a new sensor?
Thanks, Mike |
#22 (permalink) | |
Quote:
You can either get one from the dealer or online from one of these guys: http://yotatech.com/showthread.php?t=88539
__________________
#23 (permalink) |
Went to the dealer today and got what I think is the correct MAF sensor/meter. It is part # 22204-07010
They didn't have new screws for mounting it. Does anyone what type of screw I need since one of my is stripped? I may be able to just clean the old sensor once I get it off and can return the new one. Thanks, Mike |
#24 (permalink) | |
Quote:
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 03 4Runner Check engine light | rany | 03+ 4Runner/GX470, & 05+ Tacomas | 12 | 09-24-2007 05:54 AM |
| 2000 4runner check engine light | breck_k | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 12-10-2005 06:54 PM |
| How can I check the "check engine light" codes on a '00 4Runner? | goldtaco9 | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 06-12-2004 06:28 PM |
| 99 SR5 - Check Engine Light | TRD 4RNR | 95.5-2004 Tacomas & 96-2002 4Runners | 20 | 04-03-2004 10:09 AM |
| I'd like to buy a factory fog light kit for 00 4runner sr5 | csthenight | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 01-21-2003 03:00 PM |
